oil filter woes - Kawasaki ZX-10R.net
post #1 of 19 Old 03-18-2009, 08:47 PM Thread Starter
Mythical Mod of Yore
wicked's Avatar
Send a message via AIM to wicked Send a message via MSN to wicked Send a message via Yahoo to wicked
oil filter woes
i have a k and n on my bike...the oil filter tool doesnt fit because the filter is smooth...it has a 16mm hex on top of it, but when i try to loosen the filter the socket slips...
i bought this today on the recommendation of the guy at cycle gear
and maybe im doing it wrong, but all that this did was crush the sides of the filter.
ive been changing the oil on my motorcycles for about 100 years now and have never needed to ask for advice, but i just cant get the fugger off...
any help is greatly appreciated...
wicked is offline
post #2 of 19 Old 03-18-2009, 08:53 PM
WLTD's Avatar
please post whats the outcome of this because i bought a K & N filter to put on this weekend so I'd like to know if the filter is a pain in the ass I'll just sell it.
WLTD is offline
post #3 of 19 Old 03-18-2009, 09:16 PM
photodigm1's Avatar
Take a philips head screw driver.....punch thru the sides of the filter and twist
messy but does the trick
photodigm1 is offline
post #4 of 19 Old 03-18-2009, 09:21 PM
10rhawkdrvr's Avatar
Had the same problem of trying to get my K and N off. I ended borrowing an oversize set of channel lock pliers from my riding buddy and was able to get enough of a grip to twist it off. If that hadn't worked, it would have been the screwdriver method.
10rhawkdrvr is offline
post #5 of 19 Old 03-18-2009, 09:25 PM
photodigm1's Avatar
If you punch it up thru the bottom you can drain the oil out of the filter first then proceed to take it off.....not as messy
post #6 of 19 Old 03-18-2009, 09:26 PM
ZX-10R_Sinner's Avatar
I just Heeman grip the sonufabitch's, they piss me off enough that my arm nearly turns green while ripping them off.
ZX-10R_Sinner is offline
post #7 of 19 Old 03-18-2009, 09:39 PM
Gang Green's Avatar
There has been tons of threads on this issue.
I have this remover that fits over the top of the oil filter. It is plastic and works every time.
Getting the factory filter off is a pain. Just search all the old threads. Haven't had a problem since the orignal came off.
Gang Green is offline
post #8 of 19 Old 03-18-2009, 09:46 PM
gumby092778's Avatar
Send a message via Yahoo to gumby092778
try the metal band style wrench or try a standard size socket K & N is American so standard might fit better
gumby092778 is offline
post #9 of 19 Old 03-18-2009, 09:53 PM
lyodbraun's Avatar
yeah I had the same problem with my K&N filter and I thought it was a 17mm nut on the end of those?? but the nut on my filter stripped so I put a hole in the filter to release the suction and then put some visegrips on the end and broke it free. the factory one was also a pain in the ass as my filter wrench would just spin on the end of it. but i finally got that damn thing off LOL .
lyodbraun is offline
post #10 of 19 Old 03-18-2009, 10:01 PM
La Flama Blanca
9R to 10R's Avatar
Images: 102
Get the filter pliers, they work great on these bikes.
9R to 10R is offline
handling woes tiki240 Performance and Tech 14 09-24-2008 07:25 PM
Shifting Woes ccsd111k9 Performance and Tech 2 03-07-2008 12:02 PM
air shifter woes mikeliketodrag Performance and Tech 2 12-18-2007 01:20 PM
K5 Woes part III ?? Austin10RPowers The Out House 22 07-25-2005 10:43 PM
transmission woes trikchop Performance and Tech 25 01-27-2005 11:30 AM
