Oil filter ? - Kawasaki ZX-10R.net
post #1 of 10 Old 05-20-2007, 11:15 AM Thread Starter
Oil filter ?
I tried searching first but can't find it, what is the oil filter p/n for the the 06 ZX-10R ?
Is the number the same from 04 up ?
Thanks
RPO_Z06 is offline
post #2 of 10 Old 05-20-2007, 11:28 AM
SkyDork's Avatar
The stock filter? Did you try www.buykawasaki.com and look at the parts diagrams? They list the stock number as 16097-0004, which replaces some of the older model numbers.
The Purolator x-reference numbers are 14610 (short) and 14612 (long) if you want to use one of those.
#WordCrimes
SkyDork is offline
post #3 of 10 Old 05-20-2007, 11:36 AM Thread Starter
Thanks I was looking for anything, I wanted a number to cross so I could buy a Mobil 1 or wix filter.
btw for future searching purposes, this crossed to a Mobil 1 ( M1-110 )
Thanks again..
Jamie
RPO_Z06 is offline
post #4 of 10 Old 05-20-2007, 01:36 PM
Speed Freak
garth285's Avatar
KN-303 for K&N an hi flo filter is 303
the 204's will work as well just a tad bit shorter.
garth285 is offline
post #5 of 10 Old 05-20-2007, 02:06 PM
06Neenja's Avatar
Use a longer Pure One Purolator.
06Neenja is offline
post #6 of 10 Old 05-20-2007, 03:36 PM Thread Starter
The mobil 1 M1-110 is the long version like the Purolator, I just finished the oil change and its about an inch or so longer than my stock filter was.
RPO_Z06 is offline
post #7 of 10 Old 05-21-2007, 02:07 PM
Papabear's Avatar
Since most people have a Wal-mart near by the Fram # is PH 6607. The hard part is getting the filter off when you don't have a good filter wrench. I'm going to try a swivel handle stainless steel band type filter wrench that fits 57-65mm filters. I'm pretty sure that will work. These filters are supposed to be torqued to 23 ftlb.
Just my $.02
Papa...
Papabear is offline
post #8 of 10 Old 05-21-2007, 02:54 PM
Anyone know the number of the shorter version Mobil 1 for 04-05 10R.
fun2fly is offline
post #9 of 10 Old 05-21-2007, 03:13 PM
Abiagi's Avatar
Purolator Pure One PL14610(which is the longer one) and PL14612 which is the normal size our bikes use. Alot of guys on here say to use the longer one because its longer. Most seem to think bigger = better, to each his own, but I think the more volume in your oil filter can reduce your oil pressure, which may have some adverse affects on your motor at higher RPM.
Either way the Pure One filter is a great filter. There was a link to an Oil filter review floating around here not to long ago and the Pure One scored really well.
Abiagi is offline
post #10 of 10 Old 05-21-2007, 07:01 PM
morrisjl2's Avatar
Yea...the Pure One 10 is the longer one...Will never dive into the oil preasure thing, however Pure One is at the top of the list.
This is just one of them.http://motorcycleinfo.calsci.com/Fil...tml#OilFilters
morrisjl2 is offline
K&N Filter 04 10r ram360 Parts, Gear and Accessories 0 02-15-2007 09:51 AM
K&N air filter bikerscum The ZX-10R 49 06-28-2006 02:34 PM
K&N Filter for 04/05/06 ZX-10R ghostrank Parts, Gear and Accessories 8 04-16-2006 10:14 PM
06 air filter same as 05 44 The ZX-10R 0 03-10-2006 10:51 AM
K&N Filter out yet? STREETFIGHTER50 Performance and Tech 12 12-30-2004 08:12 PM
