Oil and Coolant Dump out on 2008 - Kawasaki ZX-10R.net
post #1 of 31 Old 09-29-2010, 06:55 PM Thread Starter
mechmain's Avatar
Ok hears what happened on my brief ride today.
I was out for maybe 10 minutes, and riding along with my buds. We stabbed the throttle and all of a sudden i lost traction and the motor raced to red line. I let off and re-applied the throttle and bang right to red line again. Little did I know, the rear wheel was smoking as it was spinning. The oil dumped out all over the road, and the coolant dumped out too. Nearest I can tell it was coming from the oil filter. I pulled over immediately after my bud flagged me down (don't have mirrors on the bike so didn't see the tire spinning and smoking) maybe went 500ft. I looked through the oil level glass, and saw green coolant in it, checked the oil fill plug and it was green too. The motor sounded fine when I shut it off. Didn't sound like any catastrophic failures, but something had to give.
Anyone have any ideas at what happened?
Just kind of want to know what to look for instead of going in blind.
Im probably going to try and take the head off tomorrow and have a look. Does anyone know if i have to drop the motor to get at the head, or will it come off with it still in the bike?
BTW, the bike has 12000km on it, and it is a 2008.
Thanks for any info anyone can provide.
mechmain is offline
post #2 of 31 Old 09-29-2010, 07:15 PM
angstroma2004's Avatar
sounds like the head gasket to me
angstroma2004 is offline
post #3 of 31 Old 09-29-2010, 07:43 PM
Tee's Kawa55's Avatar
anytime you get coolant in your oil, it's gotta be the gasket
Tee's Kawa55 is offline
post #4 of 31 Old 09-29-2010, 07:48 PM
Guilty by association
CP10R's Avatar
i agree that it sounds like the head gasket, if any coolant channels cracked in the block its game over. hopefully you shut it down before any major internal problems occurred, although that can happen real fast.
CP10R is offline
post #5 of 31 Old 09-29-2010, 08:20 PM
Supercharged Mod
Make sure the oil cooler and the water pump are in proper condition before you start tearing the engine apart.
GoFaster is offline
post #6 of 31 Old 09-29-2010, 08:36 PM Thread Starter
mechmain's Avatar
ok thanks guy's.
Now will i be able to pull the head with the motor still mounted in the bike or will i have to drop the motor first?
mechmain is offline
post #7 of 31 Old 09-29-2010, 08:44 PM
Supercharged Mod
Repeat: make sure the problem is not the oil cooler!!
Do a proper diagnosis on this before you start ripping stuff apart to fix stuff that isn't broken while not fixing what's actually broken ...
GoFaster is offline
post #8 of 31 Old 09-29-2010, 08:48 PM Thread Starter
mechmain's Avatar
Oh ya for-sure. As I take the plastics off, I'll take a look at everything so I can rule the obvious things out. The last thing i want to be doing is tearing into the motor while we still have riding weather here.
I just want to know so if it does come down to the head I've got a heads-up
mechmain is offline
post #9 of 31 Old 09-30-2010, 03:50 PM Thread Starter
mechmain's Avatar
OK, here is where I'm at now, drained oil and coolant (what was left anyway), removed oil filter (spin-on type) and the outer gasket had puked out, so thats where all the fluids were escaping from. Removed oil cooler and the only o-ring on it looks to be in great shape. It is on the outer rim, Have no idea on how to inspect the internals of the cooler as it doesn't look like it can be disassembled to verify. Next thing now on the list is the water pump. Hopefully there will be an obvious o-ring or something that sticks out like a sore thumb, that caused these problems.
Will post other updates as they come..
mechmain is offline
post #10 of 31 Old 09-30-2010, 04:10 PM
Was that a K&N filter by chance? I've just read another story where the gasket puked out. Doesn't explain the coolant though.
Cocky Rooster is offline
2008 coolant Temp Proteus Performance and Tech 17 09-01-2010 06:56 PM
How to dump your girl Chosen_1 Pictures and Videos 14 04-15-2009 07:43 PM
dUMP ASS CRASH ON PINKS !! bubbaRub Pictures and Videos 18 03-12-2007 09:39 PM
Taking a dump Hattori Hanzo Pictures and Videos 21 09-07-2006 09:36 AM
