oil change questions - Kawasaki ZX-10R.net
post #1 of 18 Old 05-16-2007, 08:27 PM Thread Starter
logmaster's Avatar
I have no manual, & I did a search, to no avail, so a quick 2 questions:
What is the oil capacity?
Is the Fram PH6017A okay? Its about 3/8 inch longer than the factory one.
logmaster is offline
post #2 of 18 Old 05-16-2007, 09:40 PM
MIA Ex-Mod
Tread70's Avatar
Use the purolator pure one. PL14610
Oil capacity is just over 3 qts. I usually put in 3 crank it for a min or so, shut it down and fill to the site glass reads full.
Tread
Tread70 is offline
post #3 of 18 Old 05-16-2007, 09:43 PM Thread Starter
logmaster's Avatar
Thanks, Ill drain some out. I found a sticker low on the clutch cover when I washed it afterwards.
post #4 of 18 Old 05-16-2007, 09:51 PM
Images: 11
Hey Logmaster here is a PDA Manual hope this helps http://www.beansbaxter.com/multimedia/0607ZX10R.zip
Fullthrottle is offline
post #5 of 18 Old 05-16-2007, 10:10 PM Thread Starter
logmaster's Avatar
Thanks!
Nice avatar (I have a 99 ZRX )
post #6 of 18 Old 05-16-2007, 10:33 PM
Images: 11
UH Yea I'm Drex ZXROA I'm the one who gave you the link ZX10r.net
post #7 of 18 Old 05-16-2007, 10:48 PM Thread Starter
logmaster's Avatar
that would kinda explain it then...........doh!
post #8 of 18 Old 05-28-2007, 06:17 AM
The Movie Goer!
ZiG 9th's Avatar
Send a message via AIM to ZiG 9th
Is the bolt to drain the oil on the '06 zx10 on the left side bottom near the pipes? I wanna change my oil but i'm not quite sure if thats bolt to loosen to drain it. Can anyone tell me?
ZiG 9th is offline
post #9 of 18 Old 05-28-2007, 07:15 AM
its the bolt on the left side facing 6 O' Clock on the oil pan. use a 17mm wrench or socket. i use a PL 14610 filter.
biker_larry1000 is offline
post #10 of 18 Old 05-28-2007, 02:36 PM
The Movie Goer!
ZiG 9th's Avatar
Ok thanx! I think thatz the one i thought it was initially? I'm gonna go get at it later on.
ZiG 9th is offline
2 questions zxkid'04 Performance and Tech 23 04-11-2006 10:42 PM
Saying hello and a few questions stkr02 The Out House 11 06-22-2005 01:00 AM
Impressions and questions after doing my first oil change myself... deputydog95 The ZX-10R 30 03-02-2005 01:23 PM
MMI questions... gunit0217 The Out House 5 01-09-2005 11:33 AM
Server Change (DNS Change too) RichTJ99 The Out House 4 04-18-2004 07:43 PM
