Oil Capacity????? - Kawasaki ZX-10R.net
post #1 of 6 Old 01-09-2009, 07:32 PM Thread Starter
Oil Capacity?????
I just bought an 04 10r and need to find out what the motor oil capacity is. Before I get flamed, I have searched and searched and searched this site and NOTHING ever comes up! I'll do a search for oil capacity and get 50 pages of stuff that has nothing to do with oil. If someone knows how much oil the bike takes when replacing the filter also, I would greatly appreciate it.
OHFOUR10 is offline
post #2 of 6 Old 01-09-2009, 07:36 PM
bluedevil's Avatar
there is a tag on the bottom of the Clutch cover that gives the specs in all conditions like filter removal or not and in Liters....you don't even need a manual to find it out.
bluedevil is offline
post #3 of 6 Old 01-09-2009, 07:47 PM Thread Starter
Cool...thanks! Btw, I live in sac and mines candy thunder blue also!
OHFOUR10 is offline
post #4 of 6 Old 01-09-2009, 07:51 PM
bluedevil's Avatar
Thanks for letting me know you live in Sac....I was about to give you shit on the search thing as well but never mind I can teach you that later.
post #5 of 6 Old 01-10-2009, 02:49 PM
Gen 5 Now!!
08zx10rny's Avatar
Smile
hey on an 04 zx10r the oil capacity is 3.2 us quarts with an oil filter change and 2.9 qts without filter change. but to get it right i wouldnt even worry about getting to technical on how much goes in there because sometimes you dont get all the oil out. best is to change oil and filter, then fill until you see the oil in the middle of the side window of the clutch cover. then start the bike up for about 1 min. wait about 5-10 mins for the oil to drain back and check where it is on the window. add as necessary to get to the middle of window. but its about 3.2 qts.
GEN 5!!!
08zx10rny is offline
post #6 of 6 Old 01-10-2009, 02:53 PM
Gen 5 Now!!
08zx10rny's Avatar
you can also check some specs on kawi web site under owner info on the main screen. then choose year, cc's, then it will give you the models and click which ever you have. then click on specs and it will give you the basic specs. firing order, fork oil capac., oil capac., fuel capac., ect..... or just ask someone on this site.
GEN 5!!!
fork oil capacity logmaster ZX-6R & ZX-6RR Archives 1 07-10-2008 02:59 PM
fork oil capacity Titte Performance and Tech 2 12-07-2007 12:11 AM
coolant capacity teamgreen Performance and Tech 3 12-02-2007 03:14 PM
Electrical capacity? coastiepete Performance and Tech 4 06-05-2007 07:54 PM
oil capacity kuzco The ZX-10R 11 06-04-2004 02:40 PM
