Ohlins Steering Damper - Kawasaki ZX-10R.net
post #1 of 19 Old 07-26-2005, 08:26 PM Thread Starter
O.K., I'm gonna bite the bullet and spring for a steering damper. I have decided on an Ohlins set-up. Now the question is whether to go with the factory set up (or a clone from someone like Attack) or go with the Ohlins set up that attaches to the tank mounting bolts and the stem. If I go factory set-up which, Ohlins damper do I need as Kawasaki only seem to sell the brackets? Is there an advantage to one set-up over the other? Who has the best prices?
swjohnsey is offline
post #2 of 19 Old 07-26-2005, 11:57 PM
I would go the Attack route. It puts the damper in a relatively safe place in the event of a crash. The top mount systems just look bulky to me and are a hassle if you need to remove the tank.
afm223 is offline
post #3 of 19 Old 07-27-2005, 12:49 AM
from what i have seen the attack is a better mount. i use the hyperpro rsc myself but the ohlins is a great unit.
zfactor2004 is offline
post #4 of 19 Old 07-27-2005, 01:50 AM
yehzx10r's Avatar
I just ordered the factory set up with the Ohlins damper. I had the factory set up on my 04 zx6rr and I loved it. I heard the best dampers are the ones mounted to the fork legs.
yehzx10r is offline
post #5 of 19 Old 07-27-2005, 10:07 AM
zeta xray's Avatar
I like the Ohlins mounted side to side, under the ram air tube. Pretty cool way to do it.
Don't confuse me with facts, my mind is already made up.
zeta xray is offline
post #6 of 19 Old 07-27-2005, 10:28 AM
Supercharged Mod
I have the factory side-mounted set-up. 140mm of travel would probably be OK, but mine has 150mm just to make sure that the steering damper isn't acting as the end-stop for the steering.
GoFaster is offline
post #7 of 19 Old 07-27-2005, 10:32 AM
yehzx10r's Avatar
Can you post some pictures of how it actually looks on the bike? Is the fork clamp 1 or 2 pcs?
yehzx10r is offline
post #8 of 19 Old 07-27-2005, 04:33 PM Thread Starter
Have y'all noticed the new fork bracket on the buykawasaki.com site. Instead of being sold in two pieces it is sold as a unit and instead of being almost $200 it is now around $40. Does the factory bracket mount to the frame in the two holes? The fractory frame bracket looks very cheesy, especially for $100. The Attack fork bracket looks very similar to the factory part. The frame end looks very different?
From what I can gather the Ohlins generic damper comes in 120mm and 150mm plus some shorter lengths. Which are y'all usin'?
post #9 of 19 Old 08-01-2005, 07:31 PM Thread Starter
So I ordered the brackets for the steering damper from the folks at Attack. They give a 10% discount for ordering off the web page so the brackets cost about $120. Now I need the Ohlins damper itself. The guy at Attack said I need theOhlins SD1390 damper which is just the cylinder, no kit or anything. Who sell that? How much?
post #10 of 19 Old 08-02-2005, 08:03 AM
You can order that damper from ema-usa or slava or indysuperbikes.com
BNninja is offline
FS: Ohlins side mount steering damper for 03-04 zx6rr yehzx10r Parts, Gear and Accessories 0 06-28-2005 09:52 PM
Ohlins Side Mount Steering Damper zx7marsh The ZX-10R 18 05-05-2005 10:58 AM
where can i find cheap ohlins steering damper baba The ZX-10R 28 02-17-2005 10:17 PM
Ohlins steering damper burgerkin The ZX-10R 12 06-02-2004 12:52 AM
Harris Ohlins steering damper mounting kits PeteC The ZX-10R 42 05-08-2004 05:02 PM
