OEM Ohlins damper upgrade - Kawasaki ZX-10R.net
post #1 of 6 Old 11-09-2007, 02:38 PM Thread Starter
slav's Avatar
Send a message via AIM to slav
Not sure if this is the right place to post this but...
I found out the difference between our oem dampers and after-market...
legally Ohlins cannot mod them to be the same as the after-market, but I have a number of a guy who can. $75 is all it costs to have the best damper out there. I past mine down without even seeing how the oem was and regret it.
Guys name is Mike, 770-500-6445. tell him to reach David from Ohlins and he'll get him the parts he needs. I'm sending mine out sometime in the next week or so. He said it'll take about two weeks to send it back because they're behind right now...
slav is offline
post #2 of 6 Old 11-09-2007, 03:47 PM
1bad10r's Avatar
It's not parts needed. The oil weight is the difference. I put 45w in mine and it's stiff as sex time. So he charges $75 for a oil change. There is a thread on how do complete this process.
https://www.zx-10r.net/forum/showthre...g+D amper+mod
1bad10r is offline
post #3 of 6 Old 11-09-2007, 04:20 PM Thread Starter
slav's Avatar
I've done that but didn't use fork oil and sucked. I'll try it with the fork oil. The dude fron ohlins actually said the oem has some sort of valve that the after-market doesn't.
slav is offline
post #4 of 6 Old 11-09-2007, 05:34 PM
FAF
Rent this space
The stock Ohlins has a larger bleed orifice , the aftermarket one has different valving for sure.
FAF is offline
post #5 of 6 Old 11-09-2007, 05:47 PM
Big Daddy's Avatar
Images: 38
glad my orifices and valving is tight and intact.
Big Daddy is offline
post #6 of 6 Old 11-09-2007, 08:40 PM
FAF
Rent this space
Mine used to be ??
FAF is offline
ohlins damper oil coastiepete Performance and Tech 20 04-01-2007 05:38 AM
Fs: Ohlins Damper And Kit MAVRIK Parts, Gear and Accessories 8 03-15-2007 11:53 AM
Fork Upgrade-Ohlins Vs. Traxxion Hoser Performance and Tech 37 02-24-2007 06:50 PM
will a 06 ohlins damper fit a 04 99vorsi Race and Stunt 1 09-22-2006 11:32 PM
Ohlins Damper/Ohlins Rear shock 04-05 HKMP7 Parts, Gear and Accessories 7 04-06-2006 01:28 PM
