OEM air fitler cleaning/re-oil - Kawasaki ZX-10R.net
post #1 of 19 Old 08-09-2005, 04:49 PM Thread Starter
Has anybody clean and re-oil the stock air filter? i'v search the forum but didn't see any.
kuzco is offline
post #2 of 19 Old 08-09-2005, 04:53 PM
Still here
ZX10Miami's Avatar
No that's what you do to a K&N.
Stock you can blow off with compressed air but no oil, it's paper not gauze.
Buy a new one once you've done the work to get to it.
ZX10Miami is offline
post #3 of 19 Old 08-09-2005, 04:58 PM Thread Starter
there is oil on there. i'll be getting an oil kit give it a try. seems kind of waste even for $30 new one. getting to it is not a problem at all for me.
kuzco is offline
post #4 of 19 Old 08-09-2005, 05:21 PM
pongo's Avatar
your OEM filter has oil on it? how many miles do you have on the bike?
pongo is offline
post #5 of 19 Old 08-09-2005, 05:23 PM
Still here
ZX10Miami's Avatar
If you use a K&N kit and use the cleaner with water on the stock filter you will have a bad day, and what Pongo said.
post #6 of 19 Old 08-09-2005, 05:26 PM
busaforhire's Avatar
if there is oil on your stock filter you may want to set-up an appointment at the local kawasaki dealer...you have a problem..
05 lime green. Sato slip-on, pc3usb, bmc race filter.
"when ya lose site of why ya ride then you've lost what really matters"---THE MOTORHEAD
busaforhire is offline
post #7 of 19 Old 08-09-2005, 08:22 PM Thread Starter
okok.. i dont mean the engine oil. i did buy a new filter and it has oil on it, dont konw what kind. i figure i could use whatever oil kit for air filter available in store to re-oil after cleaning. i'll need more info.
kuzco is offline
post #8 of 19 Old 08-09-2005, 08:28 PM
Post Whore
El Diablo's Avatar
"Bottom line, when I'm on that bike, it's just me and God...And He better be holding on."- Stillie on SSB
Si vis pacem, para bellum...
El Diablo
El Diablo is offline
post #9 of 19 Old 08-09-2005, 09:13 PM
It's probably not a good idea to blow out the stock filter with compressed air. You can clean the big stuff out a little by hitting it against something solid. Inertia will cause the big stuff to fall out.
swjohnsey is offline
post #10 of 19 Old 08-09-2005, 09:31 PM
Kuzco is correct about the stock filter being oiled. It even comes sealed in a plastic bag to keep the oil in place. As far as cleaning it is concerned don't wash it. Maybe try hitting it with some compressed air and a small brush to get some of the more stubborn debris. After the compressed air the filter will probably be dry as a bone so there is where the filter oil will come in handy. My mechanic said that he normally does this when a bike comes in for routine service and the filter is just slightly dirty. If it is really trashed get a new one. 30 bucks is cheap.
madav8tr is offline
How to change your own oil & filter... El Diablo Performance and Tech 191 04-04-2016 03:10 PM
GB Scotts Oil Filter Solo-Moto-Parts Vendors deals 15 04-05-2005 06:58 PM
How to change your own oil & filter... El Diablo The ZX-10R 1 02-07-2005 11:28 PM
How to change your own oil & filter... El Diablo How To... 1 02-07-2005 11:28 PM
BREAK IN PROCEDURES FOR MAX HP TRUE OR FALSE? zixxer Archives 29 11-01-2003 12:43 AM
