At odds end with the ticking noise - Kawasaki ZX-10R.net
post #1 of 15 Old 11-07-2008, 12:19 AM Thread Starter
I have read all the posts I can find about the cam chain tensioner problem with the 04 zx-10r. I have tried the back up thing turned the bike crank backwards manually. Pushed on the tensioner withe a screwdriver. Did the back out the two holder bolts here it click once and tighten it trick. I checked to see if I had a sticky valve by taking the cams out and pushing down on all the valves. Checked all the valve retainers to see if any of the are broken and checked all the valve clearance to see if they were out of spec and they were all in. I replaced the tensioner with a new one to see if that was the culprit. My only other thought is to change the cam chain itself and the guides. The bike is a 2004 zx-10r with a little over 5000 miles. the noise was not super loud but just annoying until I started messing with the tensioner. I did do the stethoscope thing all over the engine and the noise was loudest near the tensioner. Does any one have any other ideas about what the noise could be. The thing runs great idols fine has plenty of power nothing to suggest it would have a bad valve although is sounds like the whole engine is ready to explode with all the ticking noise you can hear it well over the engine and far away from the bike. Dropping throttle you can kind of hear the chain doing something. Any suggestions would be great I don't want to sink every penny I have into this thing taking guesses.
Jnut04zx is offline
post #2 of 15 Old 11-07-2008, 11:34 AM
Retired post whore
Alien10's Avatar
Not doubting what you are describing but it is a well known fact that these engines are very noisy.
Alien10 is offline
post #3 of 15 Old 11-07-2008, 11:37 AM
Post Whore
the chain doesnt sound tensioned right
Nick.INF is offline
post #4 of 15 Old 11-07-2008, 11:40 AM
Judge Dredd Mod
mr_honez's Avatar
VERY noisy. I suggest just riding it.
BURNOUT.....
mr_honez is offline
post #5 of 15 Old 11-07-2008, 11:52 AM
MIA Ex-Mod
Tread70's Avatar
You can also have a manual cam chain tensioner installed and adjusted by your trusted mechanic. But for reference you may need to have it adjusted once or twice a year depending on how much riding you do.
Tread
2004 PBO zx10-r pazzo, seat cowl, yoshi Ti TRS bolt on, PC3, Speedo-Healer, Hyperpro, Braided lines, 16-40, Sato sets, ZG dark screen, and more.
Tread70 is offline
post #6 of 15 Old 11-07-2008, 12:00 PM
nickalltogether's Avatar
Just ride it, that's just your bike talking to you. I don't even notice the racket on either of my Kaw's anymore.
2012 Kawasaki ZX-6R-Black
Clear Alternatives Tail Light
2005 Honda F4i-Red
Commuter stuff
2003 Yamaha Zuma-Fairy Silver
TPT 70cc Kit, Leo Vince ZX Exhaust, Malossi Delta Clutch, Scott's Damper Sticker
nickalltogether is offline
post #7 of 15 Old 11-07-2008, 12:02 PM
FAF
Rent this space
Some of the ticking you hear can be the reed valves in the evap system, they can get very noisy. ZX7's had particularly noisy/ticky ones.
FAF is offline
post #8 of 15 Old 11-08-2008, 12:37 AM Thread Starter
I did order a APE manual tensioner. I would have to say this noise is louder than any chain slap or valve noise I have heard. I had two zx6rs a 98 and a 2003 636 both had the normal Kawasaki noisy valve train but this one sounds like the motor is ready to blow kind of thing. The weird part is there is not any power loss or weird idol no weird vibrations or anything. I did float a valve on my zx6r many years ago drag racing and know the sound of a bad valve and a blown engine. Has anyone ever changed the chain guides with any luck I did notice that the front guide had a superseded part number. My next plan so far is to take the cams out once more inspect the chain guides and the chain to see if there is anything abnormal and to see if I can see what is making the noise before I put on the manual chain adjuster. I did notice when I put the other new one that even going backwards forwards on the crank that it did not want to get very tight I had to near force it by pushing on the back chain guide to get the thing to click once more. It is really weird that Kawasaki would design something like that. This is my fourth Kawasaki and I before this one had high faith in them to build really good beatable machines. That 636 I had was like the energizer bunny you could ride it hard and it just wanted more. I had 30,000 miles on it and it barely showed signs of weakening.
Jnut04zx is offline
post #9 of 15 Old 11-08-2008, 12:39 AM Thread Starter
When I first got the bike I kind of thought about the air flapper valves on the top my first zx6 I missed hooking up the air tube and they made that noise that was actually the first thing I checked. I'll see how the APE works I am a little nervous using it but all my old bikes as a kid had the manual types you just have to keep up on them an not go crazy on the tightness.
Jnut04zx is offline
post #10 of 15 Old 11-08-2008, 12:55 AM
ZX-10R enthusiast
dudewhrsmybike's Avatar
I just started noticing this on my 04 10R the other day! I just rolled 10k miles early this week!
Strictly for my Ninjas
https://www.instagram.com/mistr.123/
Current Ride: 2016 ZX-10R ABS (under construction)
Former Ride: 2011 ZX-10R ABS
17/41, Woolich Racing Tuned ECU and QS, Rifleman's 1/5th throttle insert, CL XBK5 pads, Yosh case sliders, Mivv Carbon w/ Ti Akra link
dudewhrsmybike is offline
bwin.com 2008 title odds... danno46 Track 8 12-08-2007 07:56 AM
What Are The Odds Of This hale The Out House 11 09-01-2006 08:17 PM
Light Ticking Noise on Acceleration? GreenKwak The ZX-10R 1 04-28-2006 05:24 AM
ticking??? theblackone The ZX-10R 18 03-14-2005 01:42 PM
ZX 10 Ticking??? T-pole The ZX-10R 6 06-29-2004 08:41 AM
