Gen 2: 2006-2007 Octane knock? rod knock??? - Kawasaki ZX-10R.net
post #1 of 10 Old 06-22-2012, 06:10 PM Thread Starter
TexasRider's Avatar
Removed the secondaries on my bike the other day..and I will say the throttle seems to be ALOT more responsive under 5000rpm...but..now I notice when I accelerate hard from low rpms (under 3000) i get a rattle sound (doesnt sound like rod knock though) from the lower end of the motor...By hard acceleration..i mean let the clutch out like coming away from a light or making a right turn...get rolling a bit and just roll into it hard. It doesnt do it at all if i just ease on the throttle or get over a certain rpm...i can roll at like 4000rpm and just dump the throttle and theres no 'rattle' noise....anyone else experience this???
Faster than a drunk snail on valium!
07 zx10r- stolen
New bike...07 GSXR1000..BMC filter, LOR slip on, 520 conversion with -1, speedohealer, pc3 custom map with xtre settings, Galfer superbike lines front, galfer sportbike line rear, shorty levers, Yami R1 throttle tube for 1/5 throttle, PAIR mod, exhaust valve gone, ecu flashed.
TexasRider is offline
post #2 of 10 Old 06-22-2012, 06:57 PM
Supercharged Mod
One way to find out: fill up with higher octane fuel and put in some octane boost for good measure, and see if it changes.
GoFaster is offline
post #3 of 10 Old 06-22-2012, 06:59 PM Thread Starter
TexasRider's Avatar
I always run 93...and never really noticed it before I took the flys out..Kinda leary about octane boost stuff...heard one too many 'stories' lol.
07 zx10r- stolen
post #4 of 10 Old 06-22-2012, 07:09 PM
Gen2 Ripper
neverendingmods's Avatar
Octane boost wont hurt anything. Try it. Could be you are way too lean now without the flies and they primarily affect sub 5k rpm.
07-ZX10R-SOLD
, 1/5th insert, -1/+5,comp werkes decatted,PC3+multi-hub,piperX,30 dry shot,2custom maps,Ballistic EVO2,Pazzo shorties,SATO rearsets,HealTech,ZG Corsa,EBC XC Gen3 rotors,Vesrah pads, SS lines, Gen3 calipers, etc and stretched 8" so it won't flip
05-ZRX1200R-sold
04-KX500-sold
1975 RD350-garage queen
neverendingmods is offline
post #5 of 10 Old 06-22-2012, 07:14 PM Thread Starter
TexasRider's Avatar
ok..ill give it a shot then...I know i dont add a whole bottle...lol. If it IS because of a lean issue..should I notice a difference in the first tank??
07 zx10r- stolen
post #6 of 10 Old 06-23-2012, 07:01 AM
thundercoupe9's Avatar
Mine did the same thing, do not mess with the octane boost in the bottle, waste of money, I had to adjust my ignition timing maps little bit to clear it up. The reason it's pinging because the engine is getting more air and it's under more load at lower rpms and stock ignition timing is too agressive for that.
thundercoupe9 is offline
post #7 of 10 Old 06-23-2012, 07:24 AM
Evil10's Avatar
If your removed the secondaries you have to have it remapped !!!! no reason for octane booster. you have stock compression and timing.
you need a fuel and ignition maps.
Evil10 is offline
post #8 of 10 Old 06-23-2012, 11:48 AM Thread Starter
TexasRider's Avatar
Kinda figured I'd need a new tune. Need to save up some $$ and have it done.
07 zx10r- stolen
post #9 of 10 Old 06-23-2012, 05:31 PM
Maybe I miss something, but when octane is connected with rod knock?
Mine GEN1 have this knock that came from clutch/trans area and I can't figure out... check the posts....
https://www.zx-10r.net/forum/showthread.php?p=1824820
https://www.zx-10r.net/forum/showthread.php?t=115594
spirity is offline
post #10 of 10 Old 06-23-2012, 05:42 PM
Evil10's Avatar
I'm thinking he is taking about a "ping" from the motor. well at least I hope he is lol
Evil10 is offline
Gen 1: rod knock? moshpete Performance and Tech 7 06-06-2012 09:36 PM
Gen 1: Engine knock? Bad??? spirity Performance and Tech 12 06-05-2012 10:55 AM
Gen 1: Engine knock ninja10kid The ZX-10R 5 01-09-2012 03:37 PM
who would you guys like to knock the sh*t out of? master link The Out House 93 10-14-2008 11:19 PM
knock out rocketracermike Pictures and Videos 3 01-19-2007 09:16 AM
