o2 sensor install - Kawasaki ZX-10R.net
post #1 of 2 Old 03-30-2010, 09:41 PM Thread Starter
ryd2nrz's Avatar
o2 sensor install
so i got a daytona wideband that im installing my problem is i cant find anyone who will weld a titanium nut into my y pipe ( cat pipe). I have a 07 zx10r and i wanted to get it put into the flat spot were the euro bikes have oxygen sensors installed now my question is will it work if i just drill a whole install the o2 into it and use a nut on the threads from the inside so it would just be almost like bolting the o2 into the exhaust
Any info or help would be awesome
ryd2nrz is offline
post #2 of 2 Old 03-31-2010, 07:50 PM
holeshot34's Avatar
If you have the stock cat i don't think it is ti. Of course mine is a US bike, it is magnetic unlike the header. I welded mine in the back where it goes back to one pipe, since i had a single sensor, with no problems. I wanted it on the outside so it would be easy to get to, and painted it flat black. Very few people even notice it when I have it pluged off.
holeshot34 is offline
o2 sensor help stevejones1974 The ZX-10R 0 06-12-2009 10:04 AM
O2 sensor? yellow10r The ZX-10R 6 04-27-2009 09:31 AM
Tip Over Sensor ( Vehicle Down Sensor) Papo-T Performance and Tech 1 06-02-2008 08:12 AM
How to install a Scorpio alarm w/perimeter sensor JodyH Performance and Tech 35 06-26-2006 04:40 AM
Euro Install: Easiest Way to Re-install Inner Liner Under Headlight? IcePick06 Performance and Tech 18 12-30-2005 11:52 PM
