Nothing happening when I turn the key on my 04! - Kawasaki ZX-10R.net
post #1 of 1 Old 07-25-2015, 06:12 PM Thread Starter
Alrighty so the issues started about a week ago. My battery died and I replaced it with a new one. Then three days later that one died. Well I when through and tested the stator and rectifier and they both worked. So then I went through the harness and found that the main ignition relay was pretty badly melted as well as one of the stator plug. Also there was some serious corrosion ona couple of the plugs. So I replaced the main harness, stator, and ignition relay. Now when I turn the key nothing happens. No lights or anything. I went through and unplugged and replugged all the connectors thinking I forgot one and still nothing. Where should I start looking. I'm out of ideas. Thank you in advance.
GoatHerder is offline
Gen 4: Ignition key won't insert or turn.. White Fang The ZX-10R 6 01-18-2015 07:27 PM
turn key to run, kill switch off, FI primes and squeeks Armadillo The ZX-10R 12 09-18-2010 03:09 AM
The Happening Shawng2020 The Out House 20 06-18-2008 02:26 PM
'06: Can't turn key to lock position tmonroe The ZX-10R 19 08-14-2006 02:01 PM
