Not Starting - Kawasaki ZX-10R.net
post #1 of 4 Old 12-26-2008, 04:31 PM Thread Starter
0710ralford's Avatar
Send a message via Yahoo to 0710ralford
Not Starting
OK......I am definately not mechanically inclined. I can only do normal stuff like oil change, battery replace, and changing exhaust from headers on. So this might be a dumb question but here goes........I recently laid my bike down due to a dumb a^* I was riding with wrecking while stunting. Anyways it ran fine rode it all the way home. Now after taking all plastic off to replace front cowl and rear tail and to do oil change at same time. I tried to start the bike because it has not been started in a couple of weeks. Battery was dead so I tried the trusty push start in 1st which always works and it feels like while clutch is pulled in bike is responding like clutch is not pulled in. I checked cable all the way to clutch case and everything is moving correctly. I don't know what I am doing wrong. Bike will start with all plastics off and exhaust muffler removed, correct??? Someone help me out!
0710ralford is offline
post #2 of 4 Old 12-26-2008, 04:36 PM
BANNED
ZX10Rracer's Avatar
If you battery is completely dead it will not start! a fuel injection system need a minimum of current to charge the system if you battery is too low it will not prime the sys! …charge your battery on 2 amp for 10 hours and try again! it should then start!
ZX10Rracer is offline
post #3 of 4 Old 12-26-2008, 04:38 PM
jayizzo's Avatar
Cant really help you but have to say unless you are calm,cool and laid back like me i hope you did not smash your friends face in.My boy just drop my bike last fri and still has not recive the parts he orderd for me.Hope your baby turns over easier soon man.
ZX10R now i know why its called MONSTER
Go Ninja Go Ninja Go!
GIFSoup
jayizzo is offline
post #4 of 4 Old 12-26-2008, 04:59 PM Thread Starter
Thanks
Actually I figured it out so if anyone retarded like me reads this if you disconnect anything that has to do with power to your computer and then reconnect it while in 1st gear and key on you f*&^ your computer and confuse it. Pain but had to start in 2nd then put in neutral to keep running the shift through all gears while riding it but everything is great now. Thanks for trying to help though.
Problem starting sv 650 The Duke Performance and Tech 2 09-05-2007 05:52 PM
iam starting to really like this thing Enzo10 The ZX-10R 17 07-24-2007 05:24 PM
starting class XoYnAfFiToX The Out House 19 02-28-2007 10:04 PM
Hard starting when hot? Sonic 10R Performance and Tech 4 06-19-2006 02:17 PM
Help Starting Bike SiP Racing09 ZX-7, ZX-7R & ZX-7RR Discussion 6 06-13-2006 01:31 AM
