NOS ?'s please help - Kawasaki ZX-10R.net
post #1 of 14 Old 06-16-2010, 06:02 PM Thread Starter
YRR
Scavenger8620's Avatar
NOS ?'s please help
I just installed a 40 shot on my 06 and just wanted to know some simple things.
1. I have no stretch so what would be a good rpm to spray and not kill myself
2. How much will it cost to refill two 20 ounce bottles
3. Is a purge kit necessary
4. And did your bike feel different after the install, the stacks being switched around and higher rpm idling . Not when you spray, but just riding in general.
Any help and or suggestions would be great and appreciated. Thanks
Scavenger8620 is offline
post #2 of 14 Old 06-16-2010, 06:34 PM
Weazel's Avatar
Subscribed
There are three rules I live my life by:
1. No matter where you are or what you are doing always look cool.
2. Don't be a pussy
3. When in doubt refer to rule number 1
Weazel is offline
post #3 of 14 Old 06-16-2010, 07:36 PM
JLAudio11's Avatar
I'd say to hold off on spraying until prolly halfway thru 2nd. From there it's up to what you feel comfortable with. You will absolutely feel the kick in the pants of it. Honestly swb and new to nitrous it wouldn't be a bad idea to start with a 20 shot. You'll still definitely feel that. Probably wont cost you more than 5 bucks to fill those bottles. Nitrous can vary by area. Last time I was getting it, I was buying it at about $3 a lb. I think. No you absolutely do not need a purge. One big thing you should do is get it tuned for the nitrous. Just spraying the air temp sensor isn't enough. BTW Are you using a single fogger or some kind of spray bar?
'06 "Corn Burner" Edition ZX10R
w/ a lot of bolt-ons
PERFORMANCE CYCLE 2 Racing
JLAudio11 is offline
post #4 of 14 Old 06-16-2010, 07:39 PM Thread Starter
YRR
Thanks for the advice, and spray bar
post #5 of 14 Old 06-16-2010, 08:46 PM
gazx10's Avatar
nitrous
jl audio giving good advice, 20 shot much more manageable, and 40 shot will hit hard in 2nd gear, be sure not to hit rev limiter, things will happen very quickly. 20 applied early 2nd will make a good difference, 40 will drop your bottle pressures quickly reducing power anyway. start light, see how your bike and you react, and go from there. enjoy your nitrous, be safe and keep engine safe.
gazx10 is offline
post #6 of 14 Old 06-16-2010, 08:48 PM Thread Starter
YRR
thanks gazx10
post #7 of 14 Old 06-16-2010, 09:28 PM
JLAudio11's Avatar
No problem. The spraybar is definitely a great choice. Even distribution of nitrous amongst cylinders to help keep things as safe as possible.
post #8 of 14 Old 06-16-2010, 09:31 PM Thread Starter
YRR
Its a system from Boss Noss, suppose to be good stuff from what iv heard
post #9 of 14 Old 06-16-2010, 09:39 PM
sweetride10r's Avatar
1. I have no stretch so what would be a good rpm to spray and not kill myself wait till second gear 7k and up bike will probly still wanna wheelie
2. How much will it cost to refill two 20 ounce bottles price vary just payed 4.25 a lb
3. Is a purge kit necessary not at all
4. And did your bike feel different after the install, the stacks being switched around and higher rpm idling . Not when you spray, but just riding in general. shouldnt change at all just get the bike tuned proplerly and get a map switch so you can have a motor and spray map.
from what ive seen i would do valve springs so you dont get any valve float
bike is down for not but not out
turbo project is a slow go no money
Need some work done
call 586-214-2414
sweetride10r is offline
post #10 of 14 Old 06-17-2010, 12:39 PM
Springs and upgraded clutch basket. Grab a gear and the dope at the same time, so u dont go into the limiter. Limiter+dope=boom
06green is offline
nos on my 06 10 ninja r Performance and Tech 21 08-19-2011 09:12 PM
nos ? hccaamps Performance and Tech 2 05-26-2007 01:11 PM
nos gauge for nos pressure eric Race and Stunt 4 09-17-2005 11:32 AM
Nos knightrider72 The ZX-10R 8 05-24-2005 03:19 PM
nos is on!!!!!!!!!! crazyman1 The ZX-10R 15 04-19-2005 11:30 AM
