noise trouble please help - Kawasaki ZX-10R.net
post #1 of 9 Old 06-02-2007, 09:03 PM Thread Starter
ok ,fellas
i'm have 04 zx10 it has 5202 miles on it right now
i'm new to the site and read up on throttle slack and
i went ahead and took off the fuel tank and air box to get
to the throttle cables i adjusted both cables so there was just a little slack
in the throttle.then i put everything back together and now it makes
rattle noise when i ride it ,when i get on the gas it sounds fine when i let off
the rattle nosie sounds off and it louder that the exhast which is a muzzy slip on.So i went back and took the air box back off and placed silicon around the gasket to make sure there is no air leaks and it still has that dam noise.
i don't know what to do now
please help me
BluDevil
BluDevil04 is offline
post #2 of 9 Old 06-02-2007, 09:06 PM
FAF
Rent this space
Could be resonance in the airbox, does it idle okay??
FAF is offline
post #3 of 9 Old 06-02-2007, 11:19 PM Thread Starter
just checked it and it idles just fine
post #4 of 9 Old 06-03-2007, 10:42 AM
FAF
Rent this space
Can you be a little more descriptive with the noise.
One thing I have found about removing the tank is the rear pinch bolt and rubbers can cause a lot of resonance in the tank , the steel tube that the bolt runs through(inside the rubbers) was a tad too long , I filed a little off and now it is fine, I still get a little noise on decel with a low tank.
FAF is offline
post #5 of 9 Old 06-03-2007, 11:06 AM Thread Starter
ok i know there is an air leak now i can hear a whisle of air too but the nosie is on decel as well it sounds like afast clicking on the right side of the bike
post #6 of 9 Old 06-03-2007, 11:12 AM
FAF
Rent this space
The whistling is probably from around the gas cap , that is normal.
I am unsure of the fast clicking noise, are you sure it isnt the reed valves in the evap system.
FAF is offline
post #7 of 9 Old 06-03-2007, 11:13 AM
FAF
Rent this space
Check to see that all your hoses are connected to the Kleen system , sounds like one of them has come off.
FAF is offline
post #8 of 9 Old 06-03-2007, 11:41 AM Thread Starter
ok i'll check them and i want to thank you so much for helping me
thanks
post #9 of 9 Old 06-03-2007, 11:57 AM
FAF
Rent this space
Not a problem, let me know what you find.
FAF is offline
Trouble?? Ken B Performance and Tech 4 04-15-2007 10:24 PM
Having trouble with the classifieds!!! Superbike1 The Out House 10 01-27-2007 08:15 AM
Trouble is like grapes! one_half_wuff The Out House 4 11-30-2006 04:07 AM
06 seat trouble shenanigans The ZX-10R 11 08-08-2006 01:33 AM
The 1 is having trouble... kawiman88 The Out House 5 05-31-2004 11:09 PM
