Noise after I install clutch basket!!! - Kawasaki ZX-10R.net
post #1 of 6 Old 05-23-2007, 08:19 AM Thread Starter
quikgix's Avatar
I broke my clutch basket rivets off basket and got it apart and dropped oil pan cleaned everything out(metal chips and chunks).Installed new basket and now I have a knocking sound while it is running! Pulled basket several times to make sure it is in right(and it is!)Still making clicking sound!I removed it again fired it up for a couple of seconds and no noise!So I know its not the rods or anything serious.I think maybe the alternator or oil pump may have debris left in it??Anyone might know what could be going on with this thing?
Now what
quikgix is offline
post #2 of 6 Old 05-23-2007, 11:24 AM
Speed Freak
garth285's Avatar
hmmm kinda tricky to tell what could be the problem..... are you are using a new OEM basket?
garth285 is offline
post #3 of 6 Old 05-23-2007, 07:17 PM Thread Starter
quikgix's Avatar
I have a good used basket!
Now what
quikgix is offline
post #4 of 6 Old 10-15-2010, 08:34 AM
fixed?
Did this ever get fixed i have same problem??????
Smokin07 is offline
post #5 of 6 Old 10-15-2010, 09:30 AM
Send a message via AIM to Cycle Concepts
If this is an 04/05, you must have matching basket and crankshaft..it doesn't matter for the 06+...also check the crankshaft gear to be sure that it did not get any trash in the gear cause that will give you a "knocking" noise every time that spot comes around on the gear..
Cycle Concepts is offline
post #6 of 6 Old 10-15-2010, 09:38 AM
My bike is an 07 i will deff check that when i get home read my thred for details please
Smokin07 is offline
aluminum clutch basket?? blakzx10 Performance and Tech 6 05-18-2007 02:10 PM
Can't get clutch housing (basket?) all the way in RussMcB Performance and Tech 5 03-23-2007 11:19 PM
clutch basket and hubs pec2903 Wanted: Buy or Trade 1 03-22-2007 10:56 PM
What size is the clutch basket nut? 1FatNinja Performance and Tech 12 03-02-2007 01:04 PM
Will 03-04 ZX-6RR clutch basket fit in the ZX-636 same year? BrianRacerboy ZX-6R & ZX-6RR Archives 3 12-17-2006 08:42 PM
