Gen 2: 2006-2007 No Start... - Kawasaki ZX-10R.net
post #1 of 14 Old 11-05-2019, 04:39 PM Thread Starter
KEValenta's Avatar
No Start...
Hey everyone. So I’ve recently powdercoated a bunch of parts on my 07 ZX10R; frame, swing arm, forks, wheels, etc. After putting everything back together it’s not starting. Cranks over fine. Getting spark, fuel pump primes, good compression. Took my injectors out and manually cleaned each one with pressurized carb cleaner. I’m in Arizona where it’s starting to get cold at night. It seems to start for a few seconds at night when temps drop. Runs really rough and will back fire super loud. Can’t get it to run in the daytime when temps rise about 75. Messed with idle screw but doesn’t help. If anyone has any input I would really appreciate it.
KEValenta is offline
post #2 of 14 Old 11-05-2019, 05:34 PM
gaz
recheck injector plug up and coil plug up, injecting fuel or firing out of sequence.
gaz is offline
post #3 of 14 Old 11-05-2019, 08:23 PM Thread Starter
KEValenta's Avatar
I will check again when I get home but I’m pretty sure the Injectors & coils are all plugged in correctly. Followed the routing from the service manual.
post #4 of 14 Old 11-05-2019, 11:36 PM
michael4012's Avatar
Have you balanced the throttle bodies since re building? If you used excessive force removing replacing the injectors the bodies are likely out of synq.
michael4012 is offline
post #5 of 14 Old 11-05-2019, 11:38 PM
You may even have dislodged vacuum pipes or bent the STP rods.... have a good look check everything and balance them.
post #6 of 14 Old 11-06-2019, 12:56 AM Thread Starter
KEValenta's Avatar
Michael4012 thank you for the feedback. I actually just hooked up vacuum hoses from my sync gauge to the throttle bodies today so they can be synced. Took out the adjuster screws for each port and sprayed carb cleaner through them. The bike won’t run though so I won’t be able to sync until I figure out what’s wrong. The vacuum hoses that are on the back side(facing rear of bike) of the throttle bodies were never tampered with. Not sure what an STP rod is.
post #7 of 14 Old 11-06-2019, 07:22 AM
Sorry STP not on G2 my mistake
post #8 of 14 Old 11-06-2019, 07:24 AM
Secondary throttle plates (butterflies)
post #9 of 14 Old 11-06-2019, 07:26 AM
Sorry I am having a bad day too when you let ignition do the STP move as normal or are they stuck?
post #10 of 14 Old 11-06-2019, 07:27 AM
Damn if got to stop posting from my phone....big finger little symbol syndrome
