no start - Kawasaki ZX-10R.net
post #1 of 7 Old 02-17-2015, 04:13 PM Thread Starter
Question no start
so...the boy decided to run in third gear instead of fourth.....as he let off for turn one there was silence then a boom. When checking for damage, we found a nice fist sized hole in the block and the remains of a rod or two...oh well. We(I) found another motor had it ringed and bearinged it but it wont start......I've looked at the trigger wheel(right side crank end cover) and it looked exactly the same but I did use a different cam sensor(the other got broken).....any ideas? This sux and the season starts in two weeks...different motors (same year) use different sensors? am i just screwed here? help help!
Mad805Mike is offline
post #2 of 7 Old 02-17-2015, 04:14 PM Thread Starter
got lots of fuel pressure (60psi!) and lots of spark too. Injector pulse was found by another mech.
post #3 of 7 Old 02-17-2015, 04:16 PM
Crash Test Dummy
Hernando's Avatar
Send a message via Yahoo to Hernando Send a message via Skype™ to Hernando
What year is the bike?
Hernando is offline
post #4 of 7 Old 02-17-2015, 05:29 PM Thread Starter
supposedly the motor is an 04-05
post #5 of 7 Old 02-17-2015, 06:43 PM
slothman's Avatar
if you have fuel and spark, it has to be a sensor. Double check every wire, fuse, and sensor.
slothman is offline
post #6 of 7 Old 02-18-2015, 10:58 AM Thread Starter
cam position sensor for an 04-05...they're all the same?
post #7 of 7 Old 02-18-2015, 07:30 PM
slothman's Avatar
CPS should be same for 04 and 05. 06 MIGHT be different.
You sure it's getting fuel and spark 100% ? It's either that or missing compression, or a sensor. Check the neutral safety switch and kickstand switch.
Is it turning over at all ? Or just cranking and no start?
slothman is offline
Tags
no start, zx10r
Gen 4: walk around/review + start up the start to youtube channel rob 2fast4u Pictures and Videos 6 06-02-2013 11:17 PM
Gen 1: Will only start after 3 start attempts Simonvez The ZX-10R 7 04-30-2013 10:33 PM
I want my ZX to start. Help... martin_achtung The ZX-10R 3 07-25-2009 02:25 PM
!!! No Start !! speed4life Performance and Tech 6 06-08-2007 07:44 PM
no start solarbeast06 The ZX-10R 12 03-22-2007 08:14 PM
