No Power On Top???? - Kawasaki ZX-10R.net
post #1 of 44 Old 11-01-2005, 07:55 PM Thread Starter
No Power On Top????
Hoping someone can help me diagnose a problem...
Bike: '04 ZX10R, 3,600 miles, bone stock.
Symptom: The bike won't run wide open throttle (under way, of course). Doesn't seem to be miss firing, just stops pulling at around 7,500 to 8,000 rpms. Pulls better under part throttle than at full throttle.
Additional info: Ran several tank fulls of high octane fuel, approx 112; maybe leaded, not sure. I pulled the exhaust can off suspecting the cat is plugged but performance did not change.
Thanks in advance for any ideas!
TN10 is offline
post #2 of 44 Old 11-01-2005, 08:17 PM
PostWhore
GuitarPlyr's Avatar
Send a message via Yahoo to GuitarPlyr
High speed generator?
John 8:24:
Therefore I said to you that you will die in your sins; for if you do not believe that I am He, you will die in your sins."
GuitarPlyr is offline
post #3 of 44 Old 11-01-2005, 08:19 PM
PostWhore
GuitarPlyr's Avatar
similar?
https://zx-10r.net/forum/showthread.php?t=10935
John 8:24:
post #4 of 44 Old 11-01-2005, 08:24 PM
bluedevil's Avatar
Get that bike to a test and tune center and put it on a dyno under load to see if they can find the problem, maybe someone here has had similar situation but that would be the fastest way to find the culprit IMO. Let us know.
bluedevil is offline
post #5 of 44 Old 11-01-2005, 08:26 PM Thread Starter
I'm not hearing any funny noises. Would a generator problem result in the motor running out of pulling power as the rpms come up?
TN10 is offline
post #6 of 44 Old 11-01-2005, 08:27 PM
PostWhore
GuitarPlyr's Avatar
...and, heres more on the generator
http://forums.13x.com/showthread.php?threadid=72463
if you need more research, search "generator"
John 8:24:
post #7 of 44 Old 11-01-2005, 09:10 PM
I'm guessing a faulty TPS. But get it checked and let us know.
Birdman is offline
post #8 of 44 Old 11-01-2005, 11:13 PM
10 speed's Avatar
your bike is in "safe" mode it wont allow you to go over 7000 RPM it has to go to the dealership to have a code read. you can read it yourself but with out the dio machine its useless
10 speed is offline
post #9 of 44 Old 11-02-2005, 01:48 AM
LordBadly's Avatar
Images: 13
Yup thats what im guessin also, mine had that problem once and it turned out to be the Sub Throtle Position Sensor. Its covered under warranty at least it should be. Just an F.Y.I. you cant buy just that piece, you have to buy the whole F.I. system. It runs over a grand. Im dunno wtf they were thinkin when they designed that but thats the way it is. Take it to the shop and see what they say and hopefully its nuthin serious! May the Force Be With You!!
LordBadly is offline
post #10 of 44 Old 11-02-2005, 06:11 AM Thread Starter
Thanks for the input. One question about "safe" mode, shouldn't one of the lights be on or blinking or something on the instrument cluster?
TN10 is offline
Sale - Michelin Pilot Power & Pilot Race - Mri ridersinc Vendors deals 0 09-07-2005 09:25 PM
For all y'all Michelin Power Fans... hillcountry10r Performance and Tech 4 08-20-2005 03:08 PM
Power Commander - PC3usb Sale flatout Vendors deals 7 01-28-2005 11:36 AM
Power Commander USB question NWZX10 Performance and Tech 7 10-26-2004 12:41 PM
True top speed Green&Mean The ZX-10R 40 10-04-2004 11:01 AM
