Gen 2: 2006-2007 No oil pressure after head install - Kawasaki ZX-10R.net
post #1 of 5 Old 04-29-2011, 07:20 PM Thread Starter
THECYKOTIK1's Avatar
Angry No oil pressure after head install
just put in race cams, kawasaki race springs, and thin head gasket. Now the oil light will not shut off. I tried the loosening of the filter like the sticky said and nothing. Anyone have any ideas? Bike fires right up but no oil pressure. FI light is on too but I don't have the air temp sensor plugged in. I'm very concerned about the oil pressure light and wondering if anyone's experienced this? HELP!!
Full Ti/CF Akrapovic EVO system, K&N filter, .045 Head gasket, Shaved & Ported head, Kawasaki race valve springs, Kawasaki race cams, PCIII + Ignition Module w/ rev extend, Removed secondary butterflies, Ivans TRE, PLX wideband, Orient Express clutch springs, Cut-down seat, Rifleman throttle insert, Muzzy links/Schnitz strap
THECYKOTIK1 is offline
post #2 of 5 Old 04-29-2011, 08:08 PM
Maddevill's Avatar
Talking Hmmm
Your pump may be cavitating. The head work shouldn't affect the oil flow assuming you didn't leave a rag in there somewhere. Try starting and blipping the throttle a couple of times. That's what I have to do every time I change my filter. Good luck and keep us posted.
Maddevill is offline
post #3 of 5 Old 04-29-2011, 08:26 PM Thread Starter
Whew. Revved it a little and went away. Was scared to rev with the oil light on. Thanks man really appreciate it.
post #4 of 5 Old 04-30-2011, 01:51 AM
Kawawog's Avatar
Send a message via MSN to Kawawog
Happy days
Kawawog is offline
post #5 of 5 Old 04-30-2011, 01:15 PM
Maddevill's Avatar
Talking Whoo hoo!
Glad it worked out! Have fun!
SSB's 04 vs 2010 ZX10R Head to Head hellsrazor The ZX-10R 50 09-02-2011 07:54 AM
No brake pressure after CBR calipers install mentis imperium Performance and Tech 44 10-26-2009 03:48 PM
Stock Install Height for GEN 1 head flashf3 Performance and Tech 1 08-05-2009 10:01 PM
Head to head my 10 & 05 Gixxer 1000 ZXTOM The Out House 28 05-12-2006 10:37 PM
Euro Install: Easiest Way to Re-install Inner Liner Under Headlight? IcePick06 Performance and Tech 18 12-30-2005 10:52 PM
