Gen 3: 2008-2010 Nissin Calipers - Kawasaki ZX-10R.net
post #1 of 9 Old 01-30-2011, 07:05 PM Thread Starter
ZXRANDY's Avatar
Nissin Calipers
Would it be a upgrade to fit some Nissin Capilers off the ZX-14 on my 08???? I know The brakes are pretty good as they sit now but i want a little more braking power.
ZXRANDY is offline
post #2 of 9 Old 01-30-2011, 07:11 PM
kbb
Sure some brake lines and some fresh fluid would't do the trick first? G/L
kbb is offline
post #3 of 9 Old 01-30-2011, 07:12 PM
Riding4life's Avatar
Send a message via Yahoo to Riding4life
I have a set of Nissin calipers, braided brake lines and better fluid setting in my garage, I will probably put them on next weekend. Stock are good but Nissin, lines and better fluid are alot better in my book.
Riding4life is offline
post #4 of 9 Old 01-30-2011, 07:23 PM Thread Starter
ZXRANDY's Avatar
Just fitted SS lines, new fluid, and new pads NEED MORE
ZXRANDY is offline
post #5 of 9 Old 01-30-2011, 07:29 PM
RDLYN13000's Avatar
Images: 38
PM flthy1 if you need a set, I think hes got an extra one laying around!!
RDLYN13000 is offline
post #6 of 9 Old 02-07-2011, 05:51 PM Thread Starter
ZXRANDY's Avatar
thanks
ZXRANDY is offline
post #7 of 9 Old 02-07-2011, 06:59 PM
Poop's Avatar
What kind of pads did you put on?
Poop is offline
post #8 of 9 Old 02-07-2011, 07:11 PM
RDLYN13000's Avatar
Images: 38
Ya know a nice brembo MC would completely transform your brakes!!
post #9 of 9 Old 02-10-2011, 09:46 AM
I've got 310mm discs from a ZX14, the same size as gen 3, and I've tried ZX14 Nissins and 08 Gen 3 Tokicos. The Nissins are much stronger, I had oem pads in both sets, and I felt they were a bit too much for the road on my Gen 2.
I think you'll need spacers if you use the Nissins, I'm pretty sure the Tokicos have an extra 5mm-ish built into the caliper.
doug_uk is offline
nissin calipers is there more to it.... kutter General Motorcycle Discussions 21 07-14-2010 07:04 PM
Nissin Calipers Chosen_1 eBay & Auction Links 0 05-07-2010 01:39 AM
Nissin calipers photodigm1 Parts, Gear and Accessories 4 02-16-2010 11:29 PM
08 10R Nissin calipers on a 06 636? rbray The ZX-10R 3 11-24-2008 02:41 PM
Got my nissin calipers on. superman10r Performance and Tech 20 02-23-2008 12:38 AM
