Nissin caliper brake line length question - Kawasaki ZX-10R.net
post #1 of 4 Old 01-13-2008, 10:00 PM Thread Starter
Hey guys need some info. I searched for info on the install of the zx14 calipers on an 06 but didn't find exactley what I was looking for. Here's my question, I have the Nissin calipers so I started to check out the install and noticed that the stock lines mount in the middled of the caliper where the Nissins mount the lines at the top. This would mean that there will be extra line length from the MC to the caliper and the cross over line will also have excess. Did you guys that have done this mod use the stock lines or is there a better fit out there oem or after market for this conversion?
Thanks.
Speedslave is offline
post #2 of 4 Old 01-13-2008, 10:03 PM
Ken968's Avatar
I did everything using stock lines. I noticed the same thing but so far no problems.
Ken
Ken968 is offline
post #3 of 4 Old 01-13-2008, 10:09 PM
Big Daddy's Avatar
Images: 38
Thanks.
certainly makes sense given the mounting location. You can purchase aftermarket ss-line kits that will eliminate the cross over and have 2 seperate single lines from the MC down to each caliper if you choose.
Big Daddy is offline
post #4 of 4 Old 01-13-2008, 10:15 PM
Retired post whore
Alien10's Avatar
When I did the caliper & m/c conversion on my 04 I used 06-07 Galfer stainless lines - perfect bends and length.
Alien10 is offline
Front brake caliper question... Older Guy Performance and Tech 7 09-07-2007 10:12 PM
Brembo brake line question EAST-LOS Performance and Tech 1 04-23-2007 11:04 PM
galfer brake line question Wind Draft Performance and Tech 14 03-21-2007 01:40 AM
Rear brake line length Hoser The ZX-10R 4 02-19-2007 12:17 PM
brake line question bellevuetlr Performance and Tech 6 04-20-2006 02:36 PM
