New tire= frontend shake? - Kawasaki ZX-10R.net
post #1 of 21 Old 10-26-2008, 08:22 PM Thread Starter
i got a new tire put on my bike today and of course i wasnt going wild on turns with it, but i did get on the highway and when i got over 140mph i started getting a shake. i thought it might be the road so i tried again and right after 140 it stared again.
do tires need to get worn in first for top end or do i need to go pimp smack the little aholes that "balanced" my tire?
fourdoorracer is offline
post #2 of 21 Old 10-26-2008, 08:23 PM
KaTooM's Avatar
KaTooM is offline
post #3 of 21 Old 10-26-2008, 08:25 PM
Wolfe's Avatar
Send a message via AIM to Wolfe Send a message via Yahoo to Wolfe
check your wheel... I had something similar happen and I had a mild dent in my rim.. you could barely see it but it was there.. so put it on a stand and spin the wheel, check each side at a single point while it turns.. just to make sure thats not it..
good luck!
Wolfe is offline
post #4 of 21 Old 10-26-2008, 08:32 PM Thread Starter
good luck!
i just went over 180 with the same rim a few days ago and havent hit anything since.
i just wasnt sure about breaking in the tire cuz my roomate said his tire did the same the last time he got a new front tire then it went away.
post #5 of 21 Old 10-26-2008, 08:34 PM
PatrickG's Avatar
Images: 15
I have run into the same problems. Haven't figured it out yet. Had a older dunlop qualifier on it and then switched to a PP and now it is weaving all over the place.
PatrickG is offline
post #6 of 21 Old 10-26-2008, 08:41 PM
Wolfe's Avatar
hmmmm, maybe it is tire imperfection that has to wear itself out.. let us know what you find out!
Wolfe is offline
post #7 of 21 Old 10-26-2008, 08:42 PM
Postwhore with an 04
bcm0018's Avatar
Maybe it wasn't properly balanced
bcm0018 is offline
post #8 of 21 Old 10-26-2008, 09:36 PM
Daves Cycles's Avatar
No you don't have to wait to run the tire at speed in a straight line.Cornering you want to scrub them in a little bit before cornering at full lean, if nothing else just to get some heat into them.
More than likely your tire is out of balance.
05 green ZX10R,Akrappovic Evo 2 Carbon w/ hex shorty can full exhaust system,Power Commander USB,Radial front master cylinder(636),Goodridge front and rear carboline brake lines,07 CBR1000RR front brake calipers,Vesrah race front brake pads,Targa tail kit,flush mount front signals,Cabon fiber led rear signals,Ohlins steering dampers,-1 front,Speedo Healer, Pilot Power tires,Gipro Tre and gold Sato's rearsets.
Daves Cycles is offline
post #9 of 21 Old 10-27-2008, 04:08 AM
Big Daddy's Avatar
Images: 38
^^ yup sounds that way.
Big Daddy is offline
post #10 of 21 Old 10-27-2008, 05:57 AM
Gone Ridin'
twidget's Avatar
Send a message via AIM to twidget Send a message via MSN to twidget Send a message via Yahoo to twidget
I had a bad front wheel bearing do this to my wifes cruiser.
It was a bit worse in that it started at about 60 and by 80 was undriveable.
twidget is offline
shake dat moneymaker lil ninja Pictures and Videos 10 03-12-2008 08:59 AM
The Head Shake! kawasloppy The ZX-10R 13 01-03-2008 10:57 AM
How to tell set-up related head shake from imbalanced tire? lenshead The ZX-10R 14 07-10-2007 06:44 AM
Shake, Shake, Shake.... [email protected] The ZX-10R 16 09-22-2006 06:32 PM
Head shake FrEteGi The ZX-10R 15 04-09-2004 08:13 PM
