new mod to keep clutch cool - Kawasaki ZX-10R.net
post #1 of 25 Old 11-27-2009, 09:55 PM Thread Starter
rayszx10r's Avatar
Send a message via AIM to rayszx10r
A friend of mine did this mod on my bike.he took the plug next to the little window where you check oil.he put a fitting in it and ran a steel braided line to the top of clutch cover,drilled cover and put a fitting in it hooked it all up and it poors oil on the clutches at all times.he said he has done 50 or 60 bikes and that when clutches go bad the will still look new,the only way to tell they are bad is the stack height
ID:	117466   Click image for larger version
ID:	117467   Click image for larger version
rayszx10r is offline
post #2 of 25 Old 11-27-2009, 10:01 PM Thread Starter
rayszx10r's Avatar
all yeah and he put in set of ebc srk racing clutches,a set o michelen power one tires.these tires are great too,clutch is smooth.
post #3 of 25 Old 11-27-2009, 10:11 PM
All show and all go 10r
JLG0987's Avatar
Is there really Enough pressure to push the oil.
JLG0987 is offline
post #4 of 25 Old 11-27-2009, 10:15 PM Thread Starter
rayszx10r's Avatar
according to the guy that done it,it works good.he has done 50 or 60 bikes and i asked him out of all the bikes he done how many blew he said none.he came highly recommended to.from what i here he builds turbo bikes and makes his own parts
post #5 of 25 Old 11-27-2009, 10:17 PM
^ thats what id say. i dont think there is any pressure at all (according to the law of connected vessels)
take the to fitting out and start the bike. keep the top fitting loose above the oil fill hole and see if there is any oil coming out of it
mityaz is offline
post #6 of 25 Old 11-27-2009, 10:22 PM Thread Starter
rayszx10r's Avatar
alright i will try that tommorrow and let you now
post #7 of 25 Old 11-27-2009, 10:28 PM
one more thing, ithink there is oil on the clutch plates at all times. that what wet sump is (referring to crank). but as the oil squirts and splashes in the pan it gets on the clutch. i tried looking at the clutch plates with the engine running (looking through the oil fill hole) and oil was coming out of the fill hole (not alot - just sprinkles).
i dont mean to sound like a dick about the mod, but thats what i have experienced so far.
mityaz is offline
post #8 of 25 Old 11-27-2009, 10:34 PM
Speed Freak
garth285's Avatar
I have seen this dont but only as a place to return turbo oil. The input shaft has a oiling hold that exit's out of the shaft and directly into the clutch pack which centrifugally will splash outward. I think this oil mod will only hit maybe the outisde of the pack and just fling off.
garth285 is offline
post #9 of 25 Old 11-27-2009, 10:40 PM
BobFinnell's Avatar
This is just my , But any oil added too the outside of a spinning clutch pack will just fling off. Clutches are oiled from the inside and the oil slings outward. Not to mention the oil galleys on the right side of the by the crank were the plug is that he tied into feeds oil to the head ( cams ) so if that takes enough pressure away from that galley you will need a new head and cams in the future. That hose is lower than the head and fluids will follow the path of least resistance.
08 ZX-10r Lime Green | Full Akra | BMC street filter | Bazzaz Z-Fi W/map switch, Bazzaz Z-AFM | Secondary's Removed | GPR V4K | Scorpio i-900 | Wood Craft sliders | Roadlok disklock
BobFinnell is offline
post #10 of 25 Old 11-27-2009, 11:05 PM Thread Starter
rayszx10r's Avatar
the guy seemed liek he new what he was talking about.he worked at a dealership as a mechanic then with a guy named buch dickerson or something like that.several of my friends recomended him said he new what he was talking about .i dont know
2008 slipper clutch mod blastig Performance and Tech 23 10-23-2009 10:41 PM
Cool for me ducatibrandon The Out House 7 07-31-2009 10:07 AM
CRG Clutch Blk Clutch Lever & Lightech Gas Cap yehzx10r Vendors deals 2 09-25-2006 05:25 PM
slipper clutch & clutch plates... jarhead05 Performance and Tech 14 07-07-2005 03:13 AM
another "Really" cool mod miykl The ZX-10R 22 08-25-2004 12:58 AM
