new grips - Kawasaki ZX-10R.net
post #1 of 10 Old 07-29-2007, 04:24 PM Thread Starter
rojapar's Avatar
new grips
getting ready to install some renthal medium grips. what is the best way to secure them? are you guys using grip glue? if so, what is the best kind..the rentals came with a little tube of their glue.
i used some kinda glue that was in a yellow tube when i put new grips on my old harley...let it dry for two days and that stuff never cured...dont remember the brand, but it made a mess.
do you even realy need glue? and does anyone use the wire ties like they useon dirt bike grips?
thanks
If it smells like cologne, leave it alone.
rojapar is offline
post #2 of 10 Old 07-29-2007, 04:26 PM
conspiracy's Avatar
thanks
I use any color paint. Install it quickly before the paint dries up. You can also use hair spray.
conspiracy is offline
post #3 of 10 Old 07-29-2007, 05:13 PM Thread Starter
rojapar's Avatar
heard of using hair spray before, but also heard that if you ride in the rain and it gets wet, you grip will come lose.
rojapar is offline
post #4 of 10 Old 07-29-2007, 06:03 PM
Chickenstrip Eater
SUPER K's Avatar
Send a message via MSN to SUPER K
I've used hairspray since I rode bicycles with no problems, how's the h2o gonna get inside the grip if the spray seals it up? Grips are usually tight as hell anyway.
http://i117.photobucket.com/albums/o45/josh10r/IMG_0144-1-1-1.jpg
Sent from your mom's IPhone using dirty fingers
SUPER K is offline
post #5 of 10 Old 07-29-2007, 06:26 PM Thread Starter
rojapar's Avatar
it rains on your bars...it gets a little wet around the inside edge...slowly works its way back, and then, before you know it, it has worked its way all the way back and now the whole grip is slipping around on a slippery hairspray mixture.
rojapar is offline
post #6 of 10 Old 07-29-2007, 06:26 PM
SalKhan's Avatar
Send a message via AIM to SalKhan Send a message via Yahoo to SalKhan
Get some Grip Glue - it's cheap and works.
If you don't have an air compressor to get the grips on (the best way), try some regular KY Jelly. Water based so it evaporates.
Sal Khan
http://www.thelunchjournals.com - Updated 3/8/08!
SalKhan is offline
post #7 of 10 Old 07-29-2007, 06:29 PM Thread Starter
rojapar's Avatar
will the "tingling" or "heat up" kind work?
rojapar is offline
post #8 of 10 Old 07-29-2007, 07:04 PM
SalKhan's Avatar
Only if you put the grips on without clothing in which case please... do NOT post pix.
Sal Khan
SalKhan is offline
post #9 of 10 Old 07-29-2007, 09:14 PM
Chickenstrip Eater
SUPER K's Avatar
Out of curiosity, how does the air compressor method work?
SUPER K is offline
post #10 of 10 Old 07-29-2007, 09:28 PM
SalKhan's Avatar
Using a hand controlled compressor attachment with a small nozzle, get about half INCH of the grip started on the bar. Then fit as much of the attachment under the grip (on the inside part of it - that you started on the bar) and give it some air.
The air will spread open the grip and let you slide it on easily. It takes a little wiggling and reposition of the compressor end, but it does make it quite nice.
IME, I've noticed that making sure the bar end is completely clean and dry also makes a difference. I use either contact or brake cleaner followed by alcohol (the rubbing kind ). I then use a small wooden dowl (or a popsicle stick this time of year ) and smear a small amount of grip glue 1/3 and 2/3 on the inside of the grip in a circle. That stuff is strong, messy, and spreads easily, so a little goes a long way but move quickly since some of it tends to dry quite quickly.
But.... that's just me. I've seen and heard of the safety wiring method, but I honestly never had a use for it.
Sal Khan
SalKhan is offline
Grips for 06 10R BigDally The ZX-10R 7 09-01-2006 02:02 AM
Grips KC690 The ZX-10R 6 07-04-2006 12:11 AM
pro-grips norcal10 The ZX-10R 6 07-02-2006 10:16 AM
Grips DanoFive-0 The ZX-10R 19 12-30-2005 02:31 PM
grips guyinhershey The ZX-10R 4 06-28-2004 12:19 PM
