New Galfer rotors and barely used Pads - Kawasaki ZX-10R.net
post #1 of 8 Old 03-10-2011, 02:14 AM Thread Starter
I've got a set of Galfer rotors coming in and my question is can I use the pads I currently have on the bike. I did a search and didn't really come up with much that helped me. I'd change out the pads as I've heard you're supposed to with new rotors, but I've got a set of Vesrah RJL that have maybe 1000 miles on them.
Anyone care to comment on reusing the old pads? I've heard you can smooth them out with maybe 300 grig sand paper then use them?
Thanks.
slmhofy is offline
post #2 of 8 Old 03-10-2011, 02:42 AM
Newfie Bullet
craig_sez's Avatar
Images: 34
I would just as you said,rough up old pads and go..
Im lookin for a combo deal on some brembo calipers and rotors...Anyone know what stock gen 3 rotors are made of??
craig_sez is offline
post #3 of 8 Old 03-10-2011, 04:54 AM
BANNED
you suppose to get new pads with the rotors, but sanding them down might work to
hellboytt is offline
post #4 of 8 Old 03-17-2011, 03:05 PM
Newfie Bullet
craig_sez's Avatar
Images: 34
Here is somethin to help you decide....about your purchase...Doesnt really answer yer question but also look up somethin called "on the throttle tv"
https://www.zx-10r.net/forum/showthre...t=stock+rotors
post #5 of 8 Old 03-17-2011, 04:48 PM
Licensed Dist of HaterAde
TMY10ER's Avatar
sanding the pads down a bit will work just fine........IF you were a dedicated track rat then it might be a different story but for street use and some track days, there should be no issues at all in re-using the old pads. you'd get the full benefit and brake feel though when you do install the new pads....then you might want to run over the outer face of the rotors with some 1200-1500 grit wet/dry to knock off any glazing the old pads may have left.
TMY10ER is offline
post #6 of 8 Old 03-17-2011, 05:02 PM
GreenWithEnvy's Avatar
Originally Posted by tmy10er View Post
sanding the pads down a bit will work just fine........if you were a dedicated track rat then it might be a different story but for street use and some track days, there should be no issues at all in re-using the old pads. You'd get the full benefit and brake feel though when you do install the new pads....then you might want to run over the outer face of the rotors with some 1200-1500 grit wet/dry to knock off any glazing the old pads may have left.
GreenWithEnvy is offline
post #7 of 8 Old 03-17-2011, 05:06 PM
Newfie Bullet
craig_sez's Avatar
Images: 34
Actually if the rotors are used there is a cleaning process for rotors and pad sanding any time you change rotors is a good idea...here is somethin i found..http://www.braketech.com/index.php?o...d=18&Itemid=79
post #8 of 8 Old 03-17-2011, 05:26 PM
Good stuff! After I did changed my front calipers to the Nissan calipers off of a ZX14 I had an issue with glazing. The was way more force then stock but the glazing gave the lever an unatural feel.
Galfer Rotors on Ebay Crazi Parts, Gear and Accessories 4 11-19-2009 09:05 AM
Galfer HH pads KaTooM Vendor Deals 5 08-20-2009 09:14 AM
galfer rotors hongthaomurphy Vendor Deals 2 01-04-2009 01:57 PM
Like new Galfer HH pads for '06 ZX-10 Musikkant54 Parts, Gear and Accessories 6 09-12-2007 03:17 PM
FS: Galfer HH pads BNninja Parts, Gear and Accessories 14 05-05-2005 10:29 AM
