New Clutch WTF - Kawasaki ZX-10R.net
post #1 of 38 Old 02-16-2011, 11:04 PM Thread Starter
Certified SLOW
nolaZX10's Avatar
New Clutch WTF
So I just installed a new clutch... rode it around the block a few times, seems fine.
Now I go to the drag strip, do my burnout and now the clutch lever has a TON of play. In fact even with the lever pulled all the way in the bike still pulls forward slightly. I do the run anyway and at the end pulling the clutch in does NOTHING. I adjust it, do another run.... and had to do a TON of adjustment again (but not quite as much). WTF is going on here? Anybody else ever experience this?
nolaZX10 is offline
post #2 of 38 Old 02-17-2011, 12:59 PM
sweetride10r's Avatar
I have seen that happen on a couple of bikes ive done not sure why. after a couple of adjustments it stop and everything worked well. I have gone as far as checking stack hieght to make sure nothing was wrong. but have seen some people have the issue and something was wrong inside the clutch sack hieght was way low
sweetride10r is offline
post #3 of 38 Old 02-17-2011, 02:51 PM
zx racer's Avatar
i would pull the clutch cover and check the stack height to make sure you didnt miss anything. you dont wanna burn up your new clutch by having the wrong adjustment.
zx racer is offline
post #4 of 38 Old 02-17-2011, 03:00 PM
KevinF's Avatar
I put one in mine and had to readjust after about 100 miles. Sometimes you just have to get some fine tunage on.
KevinF is offline
post #5 of 38 Old 02-17-2011, 03:04 PM
shift's Avatar
My 05 i had to make a bunch of adj. when it was new,now i hardly ever have to even after hard runs.
shift is offline
post #6 of 38 Old 02-17-2011, 03:06 PM Thread Starter
Certified SLOW
nolaZX10's Avatar
Thanks, I'll pull it and check the stack height. What are you guys running (stack height)?
nolaZX10 is offline
post #7 of 38 Old 02-17-2011, 08:27 PM
codyc_13's Avatar
Is this the first clutch you have ever put in, not saying you did it wrong but there are a few thing people do wrong when they have never changed a clutch.
1. You are suppose to START with a fiber and END with a fiber.
2. If your bike is an 06 or up did you remember to put the 2 little "washers" between the 1st and 2nd steel? Alot of people accidentally put the washers between the clutch basket and 1st steel and it can get wedged between the basket and hub.
3. The last fiber must be rotated 1 notch from the rest of the fibers.
codyc_13 is offline
post #8 of 38 Old 02-17-2011, 08:41 PM
strkd50's Avatar
Sorry to threadjack, but what is the reason for this? I have always done it but never have been sure why other than thats the way it comes out so thats the way it goes in.
strkd50 is offline
post #9 of 38 Old 02-17-2011, 09:59 PM Thread Starter
Certified SLOW
nolaZX10's Avatar
Check on 1. and 3., don't understand why I did #3 though but I did it. If anybody could explain why I would love to know.
I have a 05, so #2 doesn't apply. Oh, and yes it is the first clutch I've replaced.
nolaZX10 is offline
post #10 of 38 Old 02-18-2011, 02:22 AM
codyc_13's Avatar
Read through this thread and see if you come across anything you forgot
https://www.zx-10r.net/forum/showthread.php?t=6525
Also did you make sure the outer hub "locked" into place, it will only go in a certain way and it will rest on the last fiber...
codyc_13 is offline
Dry clutch edouble Performance and Tech 6 08-01-2007 03:39 PM
CRG Clutch Blk Clutch Lever & Lightech Gas Cap yehzx10r Vendor Deals 2 09-25-2006 06:25 PM
05 ZX 10R Clutch raulzx10r Performance and Tech 20 08-25-2006 05:23 PM
slipper clutch & clutch plates... jarhead05 Performance and Tech 14 07-07-2005 04:13 AM
Clutch Floyd Vendor Deals 1 07-05-2005 10:24 AM
