New Chain Questions - Kawasaki ZX-10R.net
post #1 of 6 Old 06-20-2012, 09:59 AM Thread Starter
SmokinRZ's Avatar
New Chain Questions
Hello first post but I've been following for almost year. I allways loved the looks a reputation of the Gen 1 since it came out and found a nice one late last year with 9K miles mostly stock with a slip on. It has the stock gearing which drives me crazy since I have owned mostly 600s. I'm about to go with a 16T front sproket and will use a OEM z1000 sproket. I'm going to try that first before changing out the rear and see how I like it. While I'm at it I might go ahead and replace the chain. I have used EK MVXZ in the past with good results. However, I've never owned a bike with this much power. Is this chain suitable for a stock ZX10r on the street with maybe a track day or two? or do I need the more expensive ZZZ model? I certainly don't want to crack my cases and or get stranded out somewhere.
SmokinRZ is offline
post #2 of 6 Old 06-20-2012, 11:09 AM
Tee's Kawa55's Avatar
the EK MVXZ is strong enough...I'm running the same chain on my Gen 3 and it should be good...the key to a chain is maintenance
DDM Tuning HID lights| Sportech Windscreen| ASV shorty levers| Driven D3 grips| Evotech 1/4 turn gas cap| LSL sliders| Woodcraft case covers| PCV with custom map| BMC race filter| secondaries removed| EK 525 red chain| Vortex rearsets| M4 Slayer exhaust| PSR chain adjusters| Speigler brake lines| custom front and rear seat| Pro bolt aluminum bolt kit| Hellrazor servo eliminator
Tee's Kawa55 is offline
post #3 of 6 Old 06-20-2012, 11:30 AM
SkyDork's Avatar
MVXZ is a good chain. Actually probably a higher rating than OEM one. Stick to the stock 525 size and keep it well maintained and you'll be fine.
#WordCrimes
SkyDork is offline
post #4 of 6 Old 06-20-2012, 05:11 PM Thread Starter
SmokinRZ's Avatar
Thanks the EZ 525 MVXZ is what I will get.
SmokinRZ is offline
post #5 of 6 Old 06-20-2012, 05:29 PM
BigCat for Prez!
BigCat10R's Avatar
Ive only ran MVXZs i last had a 520, but just switched to the 530 to keep the rear teeth a week longer than normal
BigCat10R is offline
post #6 of 6 Old 06-20-2012, 06:35 PM
Post Whore
-Op-'s Avatar
Ive got a 525 MVXZ on my Gen 1 right now. I drag. Probably 15 passes a month total. Its got plenty of passes on it now and lots of street miles. Itll hold up. Just clean and lube it. Maintanence is the best way to prolong the chain's life, as was said.
-Op- is offline
Gen 3: Finally needing to replace chain/sprox. Questions. IggyBcool The ZX-10R 2 04-26-2012 09:19 AM
Questions on chain maintenance mark896 The ZX-10R 18 09-04-2009 03:30 PM
Quick chain questions TI10 Performance and Tech 3 04-02-2007 12:21 AM
Chain Questions 99vorsi Race and Stunt 2 04-25-2006 03:29 AM
sprocket/chain questions? alteredZX-10 Performance and Tech 9 04-12-2006 10:43 PM
