Need some suggestions - Kawasaki ZX-10R.net
post #1 of 3 Old 01-05-2010, 02:36 PM Thread Starter
PearlOrange04's Avatar
Ok so started doing an oil and plug change, also going to do air filter and remove 2nd butterflies. Looks like the gasket on the water pump is leaking alittle too, so i'm going to remove the pump for inspection. Just wondering if there is anything else I should do while I got it that far down? Only thing the bike has now is a slip-on, no PC so please keep that in mind. Thanks guys!
PearlOrange04 is offline
post #2 of 3 Old 01-05-2010, 02:50 PM
maser's Avatar
It was suggested to me by a member here, when I had the airbox off, to do the smog mod. The search button is where I found details on this. If you should consider a pcIII, now would be a good time as the wiring harness' are exposed -- or you'll be pulling off the airbox then too. GL.
Drive it like ya stole it --- keep the rubber side down !
maser is offline
post #3 of 3 Old 01-05-2010, 04:43 PM Thread Starter
no budget for PC for right now as bad as i want one. I am tune freak though so I'm sure one is in the near future
Any Suggestions? Sh5rw9nd The ZX-10R 3 02-19-2009 02:48 PM
Suggestions PLEASE! lilryder28 Pictures and Videos 26 06-12-2008 12:40 AM
need some suggestions fbmbks The ZX-10R 30 11-16-2007 12:21 PM
Suggestions? hotstang46 The ZX-10R 10 07-23-2007 11:38 PM
Suggestions for a 50 king-tony The Out House 10 06-01-2005 05:39 PM
