Need some opinions on the VALVE ADJUSTMENT - Kawasaki ZX-10R.net
post #1 of 7 Old 12-10-2009, 08:35 PM Thread Starter
Hey guys, so im doing the dreaded valve adjustments now and have a few q's.
ALL of my Exhaust valves are out of spec (normal is .17mm-.22mm) Mine are:
.15+/.15+/////////.15+/.15+/////////.15+/.15+/////////.13+.13+
Here are the intake (normal are .15-.24mm). Mine are
.15+/.20/////////.20+/.20+//////////.18+/.18+//////////.15+/.15+
Obviously the intakes are all "within" spec. But should i just increase the gaps on the .15+ to atleast .18+?
Also, was it dangerous to have .13+ on the exhaust side? Possible broken retainers?
mityaz is offline
post #2 of 7 Old 12-10-2009, 10:33 PM
Drain Fade's Avatar
Here's what the "best" thing to do is. Put all of them in the middle of your range...that way you have some breathing room and may not have to have any adjustments next time around. I've also had hardcores tell me to put them all on the loose end...it wouldn't hurt and give you even more breathing room. As to running it on .13 I wouldn't worry too much unless you're way late on your valve job, redline constantly and ride her extremely hard...and even them it's probably no big deal. .13 is just a hair tight....no real worries.
~Drain Fade
'06 Ebony Black, Supersonic Sport Tourer
A ton of shit....I want the farkles of a Gold Wing on a 150HP bike just over 400lbs ;)
Have a VFR, ZX9R or ZX10R, check out http://drainfade.com
Drain Fade is offline
post #3 of 7 Old 12-10-2009, 10:43 PM
bluedevil's Avatar
Funny you have questions because I do too....like how many miles do you have on your bike , what's your mechanical experience/tools/method to check etc. ...just find it weird ONLY exhaust is out and intake is hunky dory
bluedevil is offline
post #4 of 7 Old 12-10-2009, 10:47 PM
bluedevil's Avatar
moved to performance and tech.....please open threads in the appropriate section.
bloo
post #5 of 7 Old 12-11-2009, 06:39 AM
dsabat's Avatar
IMHO you're fine, the #4 exhaust is the only thing I would worry about, unless you have the shims you need on hand, then put them all in the middle of the range while it's apart.
Supersport teams often run lash very tight to increase lift and duration, but that's a race situation, not something you would do on the street. As long as the valve still seats fully at running temp, it will run fine and not hurt anything. A little too tight and the valve will remain slightly open during combustion, you will lose power, and eventually burn the seat.
dsabat is offline
post #6 of 7 Old 12-11-2009, 08:12 AM Thread Starter
I used a set of feeler gauges in metric. i have .13, .15, .18, .20, and .23. The bike has approx 13k miles on as of now. As for experience, i think i have a quite good understanding of what im doing. Ive amateurishly worked on cars before and both of my bikes.
I will pull the shims today and calculate the new shims i need. And then, and then i will be begging for the forum members to trade shims with me
Thanks for info guys
mityaz is offline
post #7 of 7 Old 12-11-2009, 02:05 PM
11ute's Avatar
Images: 12
this might help http://www.cyclebuy.com/shopping/hot...imkits_948.htm
11ute is offline
Valve Adjustment walkthisway21 Performance and Tech 23 06-23-2008 01:53 AM
Valve adjustment????? Spyda_ninja Performance and Tech 34 03-14-2008 06:13 PM
Valve adjustment? CP10R ZX-6R & ZX-6RR Archives 4 02-02-2008 05:10 PM
Valve adjustment done Tread70 Performance and Tech 24 10-18-2006 08:03 PM
valve adjustment on the 10 vegasdude The ZX-10R 2 05-28-2005 06:38 PM
