need some help - Kawasaki ZX-10R.net
post #1 of 17 Old 04-13-2006, 08:21 PM Thread Starter
fastburnzx-10's Avatar
Send a message via AIM to fastburnzx-10 Send a message via MSN to fastburnzx-10
need some help
you guys are prolly tired of this sprocket subject but i am having some serious troubles getting my front sprocket off.. I have tried everything.... From a 32 mil with the impact...just started to round the fuggin thing off. so i said okay ill try like 1 1/8.......it was just as loose as 32 got. then i tried 1 on the first set of flats on the nut..and it actually just twisted the down inside the nut.... then i tried to heat..but def didnt wanna do that cause of the coolant hoses....and i gota torch...i was thinkin mabey a propane torch but even then i dunno....any help would be apprecited...
Ride hard, ride fast....
08 ZX-10R (Black)
05 zx-10r (magma)-KIA---
73 Z1 900 (all original)-The Original Kawi beast
fastburnzx-10 is offline
post #2 of 17 Old 04-13-2006, 08:24 PM
PostWhore
GuitarPlyr's Avatar
Send a message via Yahoo to GuitarPlyr
you did flatten out the washer holding the nut first?....
John 8:24:
Therefore I said to you that you will die in your sins; for if you do not believe that I am He, you will die in your sins."
GuitarPlyr is offline
post #3 of 17 Old 04-13-2006, 08:27 PM
PostWhore
GuitarPlyr's Avatar
try this too
https://zx-10r.net/forum/showthread.php?t=5597
John 8:24:
post #4 of 17 Old 04-13-2006, 08:28 PM Thread Starter
yea absolulutly...that thing is flat...went around 2 3 times prolly with my gasket scraper.
08 ZX-10R (Black)
post #5 of 17 Old 04-13-2006, 08:30 PM
PostWhore
GuitarPlyr's Avatar
and, remind me....does the 32mm fit all the way back against the sprocket? or on the smaller nut?....cause i didnt use the one that fits the back part, but had no problem with mine comin loose with an impact.....i seem to think it was 27, 29 mm or something
John 8:24:
post #6 of 17 Old 04-13-2006, 08:30 PM Thread Starter
yea i have read over it...he was using a 32 mill....so did i...and started to rounded that baby off....
08 ZX-10R (Black)
post #7 of 17 Old 04-13-2006, 08:32 PM Thread Starter
yea no doubt....i used a 1 inch on it that was super snug on it....like it fit almost perfect...but i bieleve that was is a 29...cause the axle nut is a 27
08 ZX-10R (Black)
post #8 of 17 Old 04-13-2006, 08:34 PM
PostWhore
GuitarPlyr's Avatar
the 1 inch will get wedged on there and you wont get it off, ide try the smaller mm instead of the 32
John 8:24:
post #9 of 17 Old 04-13-2006, 08:39 PM Thread Starter
i dont think i can get anything on there....it started to twist the end of the nut cause ya know how the countershaft doesnt come to the end of the nut...
08 ZX-10R (Black)
post #10 of 17 Old 04-13-2006, 08:41 PM
PostWhore
GuitarPlyr's Avatar
dang man, i dunno then....maybe someone will chime in with some suggestions
John 8:24:
