Gen 1: 2004-2005 need more power - Kawasaki ZX-10R.net
post #1 of 17 Old 08-28-2012, 09:32 PM Thread Starter
need more power
my 2004 zx10 is supercharged by aa performance making 225whp 8psi, what do I need to do to make around 250-260+? Motor is completely stock. i know nothing of mechanics, what is the simplest way to get more power and not melting my engine
ninja10kid is offline
post #2 of 17 Old 08-28-2012, 10:27 PM
Post Whore
-Op-'s Avatar
better head gasket, low compression pistons, up the boost, stiffer clutch springs, piston rings just to start. Im not super knowledgeable on the subject, but I know those things are definently in the equa.tion
-Op- is offline
post #3 of 17 Old 08-28-2012, 10:48 PM Thread Starter
wow all of that for 30 more hp.......
post #4 of 17 Old 08-28-2012, 10:49 PM
Supercharged Mod
Beyond a certain point, every extra horsepower gets exponentially more expensive.
GoFaster is offline
post #5 of 17 Old 08-28-2012, 10:52 PM
Post Whore
-Op-'s Avatar
not just for 30 more. youll be able to really crank up the boost. You build the motor up to handle that kind of boost. if you really build the motor up, you can boost it over 350hp. Then youre talking about another 125whp. At that kind of boost too though, you start running into high Intake Air Temps where youll need aftercooling to cool the compressed air.
-Op- is offline
post #6 of 17 Old 08-29-2012, 12:48 AM
nakedinseattle's Avatar
well, its gonna cost you a few hundred bucks easily, and probably around a grand to get it all installed by someone who hopefully will do a proper job.
nakedinseattle is offline
post #7 of 17 Old 08-29-2012, 02:19 AM
sam_b03's Avatar
It will take some research to find out what the stock parts are capable of handling. You can only go so far before it becomes a time bomb.
War is about killing people and breaking things. It ain't the olympics. Its not supposed to be fair. Tom Clancy
ialsodontknowwhynewpeoplecantseperatetheirthoghtss owecanreadthemitmakesitunweidlyandannoyingtryingto decipherwhattheyaretryingtosaysoiusuallyjustmoveon atleastyouusedpuncuationthoughsocongratsonthatbutm aybeinthefutureyoucanhelpusalloutbecauseyouoranyon eelsewillgetmorerepliesifyoudontwriteonebigrunonth atsimpossibletoread
sam_b03 is offline
post #8 of 17 Old 08-29-2012, 02:19 AM
thundercoupe9's Avatar
Install water/meth injection kit and you'll make extra power for under $300 and will be able to put a smaller pulley on the blower and make more power.
thundercoupe9 is offline
post #9 of 17 Old 08-29-2012, 02:46 AM
shojivic's Avatar
Holy crap! Not satisfied with 225 RWHP?! You're nuts!
shojivic is offline
post #10 of 17 Old 08-29-2012, 02:50 AM
Post Whore
-Op-'s Avatar
this too can work. could net you probably another 10whp though. would be worth it. safer option too because youll keep temps down.
-Op- is offline
Thoughts on Pilot Power 2CT front, Pilot Power Road 2 rear? phasterthanyou Performance and Tech 20 11-20-2012 09:47 AM
Gen 2: Power mods for best power band? kkline_83 Performance and Tech 4 06-09-2011 10:56 PM
FS: Michelin Power One & Power Race take offs yehzx10r Parts, Gear and Accessories 25 02-16-2011 11:27 PM
Pilot power or power one HOOCH The ZX-10R 27 09-11-2009 02:38 AM
Power to Power Commander ducman The ZX-10R 3 04-12-2009 09:38 PM
