Gen 1: 2004-2005 Need info on dropping a motor, Garth? - Kawasaki ZX-10R.net
post #1 of 7 Old 02-18-2011, 01:31 PM Thread Starter
avdigigeek's Avatar
Exclamation Need info on dropping a motor, Garth?
Hey all,
I'm selling my motor and need to drop it from the frame.
Everything was fine until I got to the motor bolts on the right side.
It looks like there's 2 crown nut looking things.
Anyone know how to get those off?
What tools I shoudl grab to get them off?
We're meeting up tommorrow so need help ASAP!
Thanks in advance.
Last edited by avdigigeek; 02-18-2011 at 01:31 PM. Reason: engrish is my second lang
avdigigeek is offline
post #2 of 7 Old 02-18-2011, 02:04 PM
SkyDork's Avatar
You need the special Kawasaki socket tool part number: 57001-1450. If you can get on one of the castellated parts with a hammer and a punch, you should be able to loosen the nuts a bit, especially if it's a one-time thing.
#WordCrimes
SkyDork is offline
post #3 of 7 Old 02-18-2011, 02:09 PM
SkyDork's Avatar
Oops, that part number is for the tool for the Gen 2 & 3 nuts. It's probably the same for the Gen 1's, but I'm not positive on that.
#WordCrimes
SkyDork is offline
post #4 of 7 Old 02-18-2011, 03:07 PM
Speed Freak
garth285's Avatar
How is it that I get called on for help, I'm just some punk kid??? hahahaha
That nut is also called a castle nut... I actually made my own tool with a 24mm socket I went to the bench grinder and copied the pattern of that nut onto the socket to get it off.
I forgot how it was on the gen 1 but I think that nut goes on a bolt that you can stick a 8 or 10mm hex key in there right? try turning that hex key out and see if it will break the nut loose....
I have done the punch and hammer method as well, if you dont have a punch be easy with it but you can use a large flat head if you really need to get it out.
garth285 is offline
post #5 of 7 Old 02-18-2011, 03:35 PM Thread Starter
avdigigeek's Avatar
Well for a punk kid you've taken the 10 motor apart more than anyone I know!
I used your cam numbers in my 04 and ended up with 3 CCS unlimited titles in 2008 on the midwest season.
I did do the riding though ;-)
post #6 of 7 Old 02-18-2011, 03:36 PM
Speed Freak
garth285's Avatar
hahaha thanks dude!
I'll be 26 next Wed :-)
garth285 is offline
post #7 of 7 Old 02-18-2011, 07:47 PM
I just did a motor swap on the first gen not long ago . Dont remember using any soecial tools to get the casle nuts off. Just need a some bigger sized allan keys to turn that internal shaft IN to get clearance on the inside of the frame.
csgup1 is offline
Garth motor down :-( garth285 Performance and Tech 44 01-09-2011 03:43 PM
Dropping the Engine bikeliker The ZX-10R 26 01-25-2010 08:09 AM
Dropping Revs Weasel1976 The ZX-10R 8 06-30-2009 01:45 PM
Dropping your front end? ninjasuz Performance and Tech 29 07-05-2007 01:00 AM
ducati dropping out of AMASBK madnessracing Race and Stunt 15 09-14-2006 03:14 PM
