Need a higher pressure FPR - Kawasaki ZX-10R.net
 3Likes
post #1 of 16 Old 05-05-2019, 02:43 AM Thread Starter
Waldo's Avatar
Does anyone know of a company who is selling a FPR which is higher than stock for a Gen4?
Waldo is offline
post #2 of 16 Old 05-05-2019, 03:02 AM
badassjake's Avatar
are you looking for pressure input regulated fuel pressure?
or just looking for constant higher pressure fuel pressure?
badassjake is offline
post #3 of 16 Old 05-05-2019, 11:55 PM Thread Starter
Waldo's Avatar
Higher pressure at the injectors
Waldo is offline
post #4 of 16 Old 05-06-2019, 12:05 AM
badassjake's Avatar
You can alter the stock internal regulator to permanently increase the fuel pressure
post #5 of 16 Old 05-06-2019, 10:33 PM Thread Starter
Waldo's Avatar
Is there a write up on it?
Waldo is offline
post #6 of 16 Old 05-07-2019, 12:10 AM
You can disassemble the stock pump. It has a valve for pressure adjustment. Under the valve spring you can put a washer and get an increase in pressure.
michael4012 likes this.
max232 is offline
post #7 of 16 Old 05-07-2019, 12:28 AM
theatiss's Avatar
How thick will be that washer and how much will this affect the fuel pressure from 3.0bar which it is stock
Gen3 : Arata full exhaust , KN air filter , 520 DID Renthal , oem Ecu converted to Race Kawasaki Ecu , milled ported head , Kent camshafts , lowered , Pk shifter , 14k rev limiter . Ecu tuned by TRE ( mr Balogiannis)
http://www.youtube.com/watch?v=eLsF4A1k_ew
theatiss is offline
post #8 of 16 Old 05-07-2019, 12:33 AM
Just plug in a pressure gauge to measure fuel pressure. The thicker the washer - the higher the pressure.
p.s. With increasing pressure, the performance of the pump (any) will fall. If you have a high power turbo project, then you will most likely need to replace the pump.
max232 is offline
post #9 of 16 Old 05-07-2019, 01:05 AM
theatiss's Avatar
Yeah I was thinking if u already have this and know the result like 1mm washe ll take you from 3 bar to 3.5bar for example...
theatiss is offline
post #10 of 16 Old 05-07-2019, 01:17 AM
For GEN4 3bar - standard pressure
Approximately 1 mm washer will increase 0.5bar
theatiss likes this.
max232 is offline
K-tech 20 S SRK fpr zx10r 08-09 Nick13 Suspension and Tire Tech 1 10-14-2014 03:27 PM
Ride Height Adjuster or Higher Heels? Iculukn The ZX-10R 30 04-25-2013 10:31 PM
?? about walbro pump and adj fpr inginekilla Performance and Tech 10 04-09-2012 06:05 PM
Making the speedo read higher than 189..... garth285 Performance and Tech 16 10-13-2007 09:51 AM
motogp3 fpr xbox latdrop The Out House 3 07-05-2005 06:16 PM
