Need help with wiring diagram - Kawasaki ZX-10R.net
post #1 of 11 Old 01-28-2005, 09:06 PM Thread Starter
whoever has a service manual check and see what color of wire comes off of the left controls and is the "High Beam" wire for the lights. Please let me know.
Thanks Recon
ForceRecon is offline
post #2 of 11 Old 01-28-2005, 09:19 PM
Images: 7
looks like R/BK (red/black stripe) off of the switch.
Ground Zero is offline
post #3 of 11 Old 01-28-2005, 09:20 PM
Images: 7
I forgot to add that this is before the relay.
post #4 of 11 Old 01-28-2005, 10:20 PM
BANNED
trikchop's Avatar
n20, gotta love that shit
trikchop is offline
post #5 of 11 Old 01-28-2005, 10:21 PM
BANNED
trikchop's Avatar
are you gonna put a progressive box too recon?????
trikchop is offline
post #6 of 11 Old 01-29-2005, 08:42 AM Thread Starter
Thanks for the help! I couldn't find my test light last night and it was causing me some problems. I ended up going to Walmart and picking up a cheap one and figured it out. But, Thanks for your help and you were right! Red with Black stripe..
No, I'm not doing progressive on this one. I'm only going to put 50Hp. Dry to it. I usually only put a progressive box on my bikes if I go between 60-150Hp. on the juice. I'm had a Hell of a time getting my WOT. switch mounted just right and with so little space. Everything is going good with the install. I'm still sorta up in the air on where I want to mount the foger itslef. All the install papers these days say in the Ram Air tube but that SUCKS and does not produce the said HP. I've always done my own R\D and mounted Turbo Foggers in the Actual Air Box. I'll post some photos here soon with steps of my install and then I'll get some Dyno Time and post those too.
Thanks again Trikchop!
Recon
Here is a picture of the Micro switch and bracket installed! Hard to see because I use Heat shrink on all my connections.
ID:	1337   Click image for larger version
post #7 of 11 Old 01-29-2005, 07:13 PM
crispin's Avatar
Send a message via AIM to crispin
you are the man!
ya ya ya...
crispin is offline
post #8 of 11 Old 01-29-2005, 09:05 PM
BANNED
trikchop's Avatar
looks good bro , no problem
trikchop is offline
post #9 of 11 Old 01-30-2005, 10:19 AM Thread Starter
Crispin, No! You the MAN!! LOL!!! Got a couple new pic's of the bike for ya.. It was 68deg. four days ago and now we have 6" of snow on the ground!! Still waiting on my chain and brake line.
Recon
ID:	1348   Click image for larger version
ID:	1350   Click image for larger version
ID:	1351   Click image for larger version
post #10 of 11 Old 01-30-2005, 10:58 AM
Friggin awesome...I park all 3 of my bikes in the house also...
Roadracer174 is offline
Wiring an accessory Older Guy Performance and Tech 4 10-08-2004 04:19 PM
Buddy needs some wiring help........ RUNNINHORN Performance and Tech 2 06-29-2004 12:47 PM
Need Help With Wiring or Wiring Diagram for 2004 ZX-10 cashes41 The ZX-10R 0 05-21-2004 03:24 PM
Radar Detector Mounting & Wiring Xusia The ZX-10R 4 05-18-2004 11:39 AM
Will this wiring work for integrating my turn signals? RUNNINHORN The ZX-10R 9 05-10-2004 11:52 PM
