Need help with tires Exp only. - Kawasaki ZX-10R.net
post #1 of 13 Old 05-29-2007, 08:05 PM Thread Starter
I need some advice from a experience riders only. I have a 07 zx10r and I just made 2300 miles on it and the Qualifiers that came with is gone I need new tires and cannot find a size 190/55 what difference will it make if I put the 190/50 on it. Please let me know.
vietnow is offline
post #2 of 13 Old 05-29-2007, 08:14 PM
morrisjl2's Avatar
I am sure someone else will chime in here....the 07 is set up for the 55 series so that is what NEEDS to be on the bike. Also I have a couple of buds on an 04 that think the 55 is great on that bike as well.
morrisjl2 is offline
post #3 of 13 Old 05-29-2007, 09:09 PM
rayszx10r's Avatar
Send a message via AIM to rayszx10r
i dont no if they made the 2007 zx10 diffrent than the 06 zx10,if they did you sure cant tell my buddy has an 07 zx10r limited edition and i have an 06 and they look and perform identically except mine pulls harder,ok i got a metzler sportteck 190/50/17,and it rides good i couldnt tell no diffrence and my stock tire was the quilifier 190/55/17
rayszx10r is offline
post #4 of 13 Old 05-29-2007, 09:10 PM Thread Starter
the 06 and 07 is the same.
vietnow is offline
post #5 of 13 Old 05-29-2007, 09:15 PM
Pressley10r's Avatar
Send a message via AIM to Pressley10r
if youre an aggressive street/track rider then you may notice the difference. you'll need to raise the rear somehow or lowering the front a bit may help compensate for the shorter tire.
BIKES ARE THE FASTEST
Pressley10r is offline
post #6 of 13 Old 05-29-2007, 09:17 PM
btw there are several manufacturers that make 190/55s may i recommend pilot power 2ct(s)
post #7 of 13 Old 05-29-2007, 09:20 PM
Supercharged Mod
Bridgestone has something for you in the correct size, too.
GoFaster is offline
post #8 of 13 Old 05-29-2007, 09:44 PM
limenine's Avatar
I found PPs to be an improvemnt over the oem qualifiers even in the 50 instead of 55 series. I will try a 55 rear again - but my last two sets have been 50s with no problems.
limenine is offline
post #9 of 13 Old 05-29-2007, 10:49 PM Thread Starter
yeah the bridgestone is more a track tire even thought they are great. I will try it and maybe put a spacer in the back to raise it and see how it feels.
vietnow is offline
post #10 of 13 Old 05-29-2007, 11:34 PM
Cling's Avatar
put a 5mm spacer above the shock and use a 190/50 you'll still have less turn in but the spacer should help with the front end turn in ability. I run a Elka rear shock with adjustable height so I ran a 190/55 this weekend at the track and also a 190/60, just a few spins of the nut to raise the height about 5-6 mm and I was ready to go for the 190/60.
Cling is offline
tires please! coastiepete Vendors deals 2 02-01-2007 03:36 PM
Which tires should I get?? 06Neenja The Out House 22 01-27-2007 04:56 PM
OEM tires RaZXiel The ZX-10R 37 01-25-2007 01:28 PM
Tires hollywood99 Strip 6 11-15-2006 12:05 PM
Best Tires ???!!!?? BMW528I The ZX-10R 26 03-31-2006 07:28 AM
