Need help to slow down fast signal blinking - Kawasaki ZX-10R.net
post #1 of 15 Old 10-24-2005, 11:12 AM Thread Starter
JBJ
Because the light bulb size is different btw the new and old signals, the new signals blink much faster.
Does anyone have a fix for this...ie a resistor in the wiring or something like that...or do I just live with it?
JBJ is offline
post #2 of 15 Old 10-24-2005, 11:26 AM
I'm just livin' with it but you can add a resistor or go with a solid state flasher relay.
swjohnsey is offline
post #3 of 15 Old 10-24-2005, 11:31 AM
lexusrx's Avatar
are they led bulbs?
Retail is for squids. Shop like a pro at Superbike Supply.
[email protected]
https://www.facebook.com/superbikesupply
www.forum.superbikesupply.com
1-828-287-2101
lexusrx is offline
post #4 of 15 Old 10-24-2005, 11:36 AM
sneaky's Avatar
If you are using LED style bulbs int eh system they will flash fast as LED do not have the load ability like regular bulbs do. I ahve seen some try to make their own resistor set ups, make sure you are giving them some room as they will put off some heat that is why the aftermarket ones have huge heat sinks on them.
If you get rid of the load dependant relay and put in a non load dependant you will cure this problem, the system just will not tell you if you have a bulb out anymore.
sneaky is offline
post #5 of 15 Old 10-24-2005, 11:37 AM
Ara
LE Post Whore
Ara's Avatar
I have the libertek relay on my R1, and it lets you adjust the flasher speed.
Ara is offline
post #6 of 15 Old 10-24-2005, 01:22 PM
Post Whore
1killer1liter's Avatar
Images: 11
The Clear Alternatives tail light comes with 2 ballasts to slow the blink rate down.
I live my life a quarter-pounder at a time. And for those 500 calories or more, im free. I need FRIESSSS! Two of them. The big ones. Oh, and I need them tonight. You're lucky the double shot of BBQ sauce didnt blow a seam on your nugget box.
1killer1liter is offline
post #7 of 15 Old 10-24-2005, 11:53 PM
Clear Alternatives just released a Heavy Duty Electronic Flasher. Most applications are plug and play, for $15 you can't beat it. Lots better than messing around with installing the ceramic resistors.
dragon10 is offline
post #8 of 15 Old 10-25-2005, 12:01 AM
Big Daddy's Avatar
Images: 38
are you referring to the OEM Euro signals?? if so you simply insert the US version bulbs in the Euro signals and its all good.
Big Daddy is offline
post #9 of 15 Old 10-25-2005, 07:21 AM
Thanks! Now I have to find them stupid signals I stored away.
post #10 of 15 Old 10-25-2005, 07:45 AM
Images: 7
You can also go to any auto parts store and get a EL12 flasher relay for around $5 and replace the OEM flasher relay. Works great!. If you run a search here you will find some more info on it. Very easy to do.
Ground Zero is offline
WTB 05 signal lights JBJ Wanted: Buy or Trade 2 10-08-2005 06:16 AM
is the site really slow right now or just me zfactor2004 ZX-10r.net Site Help, Suggestions and Questions 29 08-21-2005 07:45 PM
What resistance do I need to slow the blinking rate? mods2come The ZX-10R 10 03-31-2005 11:31 AM
turn signal enigma FrEteGi The ZX-10R 21 03-15-2004 06:30 PM
