need help setting up suspension - Kawasaki ZX-10R.net
post #1 of 6 Old 02-10-2008, 03:45 PM Thread Starter
flthy1's Avatar
just curious what the proper way to set up my suspension on my 07 10.Im 270 lbs and havent touched it yet. any info would be great
flthy1 is offline
post #2 of 6 Old 02-10-2008, 04:03 PM
kawiiiiii's Avatar
Images: 19
I dont think you can set up the suspension without changing your spring rate. Most litter bikes come with spring rates for riders under 200lbs. There are a lot of posts on this, do a little search and good luck.
kawiiiiii is offline
post #3 of 6 Old 02-10-2008, 06:00 PM
mach_man_187's Avatar
Here is a good site to use for spring rates http://www.racetech.com/evalving/eng...name=eng lish
From Racetech......
Front
Rider Weight: 270 lbs.
Recommended Spring Rate: 1.048 kg/mm (use closest available)
Stock Fork Spring Rate (measured): 1.000 kg/mm (stock)
Rear
Recommended Spring Rate for Street: 10.38 kg/mm (use closest available)
Stock Shock Spring Rate (measured): 8.3 kg/mm (stock)
So it looks like the front is close but the rear is off by quite a bit.
mach_man_187 is offline
post #4 of 6 Old 02-10-2008, 06:53 PM
stock isnt 1.0 kg on the front.
twonk is offline
post #5 of 6 Old 02-10-2008, 07:20 PM
alharm1's Avatar
Yeah, this is something that Im going to try to get done when weather gets warm. Im going to use the suggested settings from sport rider magazine. I am about 200 lbs. I know that the stock settings are way to soft for me. Hopefully bike will come alive when I get sag set and adjust suspension a bit.
alharm1 is offline
post #6 of 6 Old 02-11-2008, 03:01 PM
booken's Avatar
Actually on the 06-07 10R the front springs are actually quite stiff. I am not sure it will be stiff enough for a 270lb person but I am just over 200lb with all my gear and managed to get my preload set up without running out of adjustment.
booken is offline
setting up suspension with 180/55 on an 06 10r jscho600rr Performance and Tech 5 03-15-2007 03:45 AM
suspension setting question S.ga.rider The ZX-10R 6 06-01-2006 12:56 PM
Suspension setting suggestions Older Guy The ZX-10R 20 11-21-2005 02:59 PM
factory suspension setting any idea??? hired-gun The ZX-10R 13 07-13-2005 04:32 PM
Another suspension setting question! Please help!!! Chaz The ZX-10R 2 04-13-2005 08:54 PM
