Need Help Please!!! - Kawasaki ZX-10R.net
post #1 of 11 Old 08-28-2008, 08:37 PM Thread Starter
Exclamation Need Help Please!!!
04 ZX10r I have a Arata full titanium exhaust, and a bmc race air filter, and i have removed the secondairy butterflys. with my arata map and my custom dyno map, im throwing huge flames out of the exhaust, blue and yellow flames, Prior to removing the secondary's, i still threw small blue flames, and that was ok, but now the flames are yellow and im afraid its gonna destroy my motor. i was wondering if any body might have any ideas. I dont really want to go back to zero map due to power loss. and cant really afford to get it dyno tuned right this min... Your assistance would be greatly appreciated..
Thank you
Shane
wheelieshane is offline
post #2 of 11 Old 08-28-2008, 08:56 PM
avdigigeek's Avatar
is itr onm decel only?
Smiley
nesba # 936 http://www.nesba.com/
CCS # 936 wingnutzracing.com
Sponsors
Twisted-powersports.com
DCDECALS.net
http://ask2geeks.com/
http://www.superbikeitalia.com/
"Being shot out of a cannon will always be better than being squeezed out of a tube.
That is why god made fast motorcycles"
Hunter S. Thompson.
avdigigeek is offline
post #3 of 11 Old 08-28-2008, 09:03 PM Thread Starter
yea its when u tack it up a lil bit and when it revs back down its throwing madd flames
post #4 of 11 Old 08-28-2008, 09:11 PM
ZX-10R_Sinner's Avatar
Do you have block offs installed? If that's the case you might wanna get back to the tuner, or possbily even a different tuner ASAP.
At its core, the Ninja ZX-10R is a motorcycle built for the accomplished rider who can fully appreciate its capabilities--whether put to the test at a racetrack, or merely the focus of bench-racing conversation. It is, by all standards, the embodiment of the ultimate superbike.
Member of The Elite - Growler Group
ZX-10R_Sinner is offline
post #5 of 11 Old 08-28-2008, 09:12 PM Thread Starter
flames
not sure, Im kinda new to this bike. what are the block offs exactly...
post #6 of 11 Old 08-28-2008, 09:15 PM
bugman53's Avatar
They bock off the pair valves. It lets air into the exhaust to burn any un burnt fuel before if hit the atmosphere. There on the valve cover. do a search.
High Velocity Cycles 2005 Ti ZX10R
Greeensboro NC
bugman53 is offline
post #7 of 11 Old 08-28-2008, 09:20 PM Thread Starter
flames
no they are not on there. do i need to get some asap. and should i not even ride it until then
post #8 of 11 Old 08-28-2008, 09:31 PM
Well the block offs aren't a big deal I guess, it won't cause damage to the motor as it lets clean air into the exhaust. I guess the major thing with block offs is the tune. They allow proper A/F ratio to be read when dyno tuning, so basically without block off's your custom tune is crap. Get some block off plates, and go get it tuned again. Ivan's has them for $35 plus shipping I believe, and is a site sponsor here.
post #9 of 11 Old 08-28-2008, 09:41 PM Thread Starter
ok i found a map on power commander for a arrow exhaust, stock or aftermarket filter, and secondarys removed. do u think that would work better than the arata map with stock or aftermarket exhaust
post #10 of 11 Old 08-28-2008, 09:46 PM
It's worth a shot. When I first had my bike tuned the place I was at sucked and it was extremely lean, so I put a Barracuda map or something that I thought was close to it on there. You could try an Akra map or whatever you think is closest to your set up. I know dyno tuning is expensive but it's usually the best route, but block off plates should be your first step towards getting rid of any flames/popping.
