Gen 3: 2008-2010 Need Help with noise!!!!!!!! - Kawasaki ZX-10R.net
post #1 of 10 Old 03-18-2011, 11:44 AM Thread Starter
SickAsHellTom's Avatar
Hello all My 2009 ZX10r is having a slight vibrating noise and its starting to annoy me, i had my local dealer look at it and they said that i prolly have to take my gauge out and put some tape behind it.....The sound,sounds like if the windscreen bolts wernt tight,its coming from the front of the bike like under the gauge...has anyone experienced this issue....and if so does anyone know how to remove the gauge properly so i can fix this.....
SickAsHellTom is offline
post #2 of 10 Old 03-18-2011, 12:23 PM
blink.'s Avatar
Should be pretty straight forward, remove mirrors, windscreen, front cowl, and should be bolts in the back of the fairing stay that let the gauge move freely, no need to unplug them.
blink. is offline
post #3 of 10 Old 03-18-2011, 12:46 PM
Kawboy1056's Avatar
Exactly what he said.. Your gauge cluster should have rubber grommets that attach the gauge to your fairing stay and you might have had one come off somehow..
Kawboy1056 is offline
post #4 of 10 Old 03-18-2011, 04:37 PM Thread Starter
thanks guys im gunna try to look at it this weekend and ill post results next week,thanks for the info
post #5 of 10 Old 03-19-2011, 04:55 PM
the only thing that holds ur gauge is two bolts in from each side into the neck and the 4 windscreen bolts. and that front end is not exactly easy to pull apart since the turn signals plug in under the cluster.
timmyriv is offline
post #6 of 10 Old 03-19-2011, 05:42 PM Thread Starter
Fixed
OK so i finally fixed it......Heres what happened....i took the windscreen off and the gauge bolts off...behind the gauge is a little silver brakcet that holds the wires in place to the bike( thats what was loose and rattiling like crazy) so i tighted it up and put it all back on and WALA Fix ....thanks for all that posted
post #7 of 10 Old 03-19-2011, 06:04 PM
jasonmark1993's Avatar
Nice work. Second post that was the same thing...wire retainer either loose or rubbing the cowl.
jasonmark1993 is offline
post #8 of 10 Old 03-20-2011, 03:30 AM
Hey was it this one? Mine isn't loose really, but isn't holding the wires or plugs at all.
Check out the wire insulation being worn through. 2100 miles.
post #9 of 10 Old 03-21-2011, 08:48 AM Thread Starter
BINGO...thats exactly what it was...the bolt was basically off lol
post #10 of 10 Old 03-21-2011, 09:17 PM
Hmm mine was tight. I wonder if since it wasn't bent down or holding the wires/plugs tight it was causing a noise. I also found another one of those wire retention brackets pressing up against the backside of the cowl kinda behind the right side fork. Not sure if it fixed it yet. Went for a ride with the windscreen off and I don't think it was as bad but I thought that I still heard something.
Noise on 06 10r KidCapri50 The ZX-10R 15 06-24-2006 03:15 PM
I Got A Noise zx10bikerboy Performance and Tech 6 05-08-2006 05:07 PM
hey i have a noise...... zfactor2004 The ZX-10R 18 11-07-2005 12:05 PM
noise from 04 10r grego10r Performance and Tech 11 07-28-2005 02:48 AM
Odd noise... hillcountry10r The ZX-10R 28 12-08-2004 01:40 PM
