Need Help with Nirous on 05 tps - Kawasaki ZX-10R.net
post #1 of 3 Old 11-25-2010, 04:32 PM Thread Starter
cavo's Avatar
Need to see what color wire i have to connect the throttle position sensor wire from nitrous into the harness of bike
cavo is offline
post #2 of 3 Old 11-25-2010, 04:42 PM
Certified SLOW
nolaZX10's Avatar
Cant help you there, but if you have a PCIII you can tap into the silver wire on it for TPS. Hope that helps.
nolaZX10 is offline
post #3 of 3 Old 11-25-2010, 05:03 PM Thread Starter
cavo's Avatar
yea that did work thanks i saw that the silver lined up with the yellow and white wire from engine but i had a power commander and the wire harness was different colors so i wasnt sure but 2 that say silver is better then one
cavo is offline
nirous question 1qwk10 Performance and Tech 8 06-24-2009 12:02 AM
