Gen 2: 2006-2007 Need help, my gen 2 will not start - Kawasaki ZX-10R.net
post #1 of 5 Old 09-10-2014, 07:00 AM Thread Starter
OK so here is the story. I bought this gen 2 off a friend, it is pretty much stock besides the pc3,gi pro, and full apveok exhaust. I road it a couple of weeks befor i bought it and it road strong,I was impressed and sold. When I went to go pick it up, it would not run. He tried to get it started by jumping it and using starting fluid, it would run but then shut off. So when I got it home I started searching the forms for gen 2 starting problems. First thing I did was replace the battery and nothing so then I checked the fuel pump and that worked.Sad news is it had about two inches of water in the tank. So i flushed the fuel system of the old gas and what ever water was left. I changed all other fluids just in case,still nothing. From here I went ahead and replaced the sparkplugs and had the injectors checked, cleaned and flowed. All checked out, so I have fuel,air and spark. Went to start and it started but won't idel. It started twice and now its back to not starting. So I checked all connections and for chaffing in the wire harness and also the bike down sensor and all checked out an the FI light does come on when sensors are unplugged. I checked the pc3 and there was problems with it so I updated the softwear and got it thinking right again and still nothing, we then bypassed the GI pro and pc3 and went to stock hookup and still nothing. I do have compression and the valves are not bent so right now I am at loss. When it is cranking it sounds like it is right there lik it wants to start buy wont turn over. Could it be a bent crank shaft and bad head gasket? Any one else have the same trouble with the gen 2?
BKFast is offline
post #2 of 5 Old 09-10-2014, 07:06 AM
JUICEBOX's Avatar
Might be something simple like a pinched or clogged fuel line.
82 GS450L- Bobber Project
06 636- Sold
07 R1- Lost
08 zx10r- Lost
09 zx10r- Totaled 8/3/14
07 cbr600rr- Track - Sold
12 EX250r- Womans - Kissed a guardrail
13 zx10r- Old street - Sold
14 SSR Lifan 180cc Pit Bike- Fun machine
15 zx10r- New street
I come in peace, I didn't bring artillery. But I am pleading with you with tears in my eyes: If you fuck with me, I'll kill you all.
Marine General James Mattis, to Iraqi tribal leaders
JUICEBOX is offline
post #3 of 5 Old 09-10-2014, 07:47 AM
gazx10's Avatar
try this to eliminate which system is failing, fuel or ignition. use a spray plastic bottle with gas, spray the ram air ducts in front fairing several good shots , crack throttle, and try to restart. if fires, recheck the fuel pump especially the internal fuel filter as u had water in tank. if no fire, u have a spark problem. also i have run into the common ground junction under the left small fairing under tank causing similiar problems. it's a square plastic junction box taped up in the harness that feeds the sensors and fuel/spark systems. your main ground cable off the battery runs directly to it. must be pried apart, contains over ten ground junctions on a common bar. had one badly corrodded that gave me fits finding the no start problem. no warning when this box acts up, running good one moment, no start next. let u know what u find.
gazx10 is offline
post #4 of 5 Old 09-10-2014, 07:54 AM Thread Starter
OK thanks, I will give all of this a try this weekend. I'll keep you guys posted
BKFast is offline
post #5 of 5 Old 09-15-2014, 08:13 AM
The Movie Goer!
ZiG 9th's Avatar
Send a message via AIM to ZiG 9th
Mine won't start either. It's not even crankin over or tryin to start. I got nothin. Everytime I hit my starter button my Fi light starts blinking. Is yours doin that too?
<img src=http://i261.photobucket.com/albums/ii64/thebluehanger/Thriller.gif border=0 alt= />
Quote of the year! lol!!
"1 shut the fuck up 2 ur opinion doesnt count on this kind of page where saw fans come together 3 you fucking liked you own comment thats fucking pathetic!" -Brandon Welbig
ZiG 9th is offline
Gen 2 No Start issue rkd The ZX-10R 3 04-27-2013 05:46 PM
Gen 2 won't start mishanja The ZX-10R 19 09-11-2012 07:05 AM
Gen 1 wont start BiggCee442 Performance and Tech 11 05-01-2012 02:14 PM
Gen 3: HELP..!! GEN 3 wont start.... KIRK_ADAMS Performance and Tech 18 10-18-2011 10:04 PM
My Gen 1 won't start Dundeal1980 The ZX-10R 16 09-16-2011 01:44 PM
