need help installing 16t - Kawasaki ZX-10R.net
post #1 of 13 Old 01-02-2005, 03:24 PM Thread Starter
n e body know wat size socket i need to change the front sprocket???
im in the process but it looks like i dont have the right size sockets
thanx
zexxx04 is offline
post #2 of 13 Old 01-02-2005, 03:27 PM
27MM socket and be sure to take a punch or screwdriver and flatten the soft washer/keeper that is behind the nut. You will see what I mean when you get the cover off! Just did it two days ago! Recon
ForceRecon is offline
post #3 of 13 Old 01-02-2005, 04:22 PM Thread Starter
thanx alot recon
zexxx04 is offline
post #4 of 13 Old 01-02-2005, 06:18 PM Thread Starter
wwwoooowwwwww.... i finally put it on super easy with the impact gun and 27mm socket then everything else is easy to install... but damn wat a difference i love it i took it out for a quick spin and im a beliver lol all i need to install now is the tre and im ready to go...........
zexxx04 is offline
post #5 of 13 Old 01-03-2005, 12:30 PM
I need an air gun. I used a 32mm socket and grabbed the back piece of the nut.
Do you have an air impact or electric? If electric works, I'm going to be cheap.
BNninja is offline
post #6 of 13 Old 01-03-2005, 03:34 PM Thread Starter
electric is wat i used
and it was so0o0 easy
zexxx04 is offline
post #7 of 13 Old 01-03-2005, 03:49 PM
MIA Post Whore
miykl's Avatar
The electric one I used wouldn't budge the nut. Ended up using a breaker bar with a four foot cheater.
miykl is offline
post #8 of 13 Old 01-03-2005, 04:37 PM
bluedevil's Avatar
Same here, air gun did not buldge the nut. I only needed a 25" breaker bar and having a hydrolic lift to keep the bike steady doesn't hurt either.
bluedevil is offline
post #9 of 13 Old 01-03-2005, 05:16 PM
I used a snap-on cordless 1/2 impact gun and worked great. Are you sure you flattened out the back washer first????? Before trying to remove the nut? Just a question?? Recon
post #10 of 13 Old 01-03-2005, 05:54 PM
bluedevil's Avatar
I know I flattened mine out first. I have a new digital torque reader that goes up to 150lb-ft and I tested used it to see how tight the nut was. Well never got a chance to digtal unit bleeped out because I went over the scale limit... yeah that bolt is tight. I am getting ready to take the bolt off today because of some spocket issues but I am curious to see how high the 92lb-ft that I set it at increased will report back later if anyone's interested.
First ride with 16t countershaft sprocket... El Diablo Performance and Tech 92 09-03-2006 06:44 PM
AFAM vs Kaw 16T... Ground Zero The ZX-10R 41 07-20-2006 04:49 PM
16t knightrider72 The ZX-10R 37 01-04-2005 06:22 PM
16t sprocket fbdr24 The ZX-10R 2 11-07-2004 12:19 AM
16T Sprocket - How hard is it to install this? RichTJ99 Performance and Tech 24 06-30-2004 03:23 AM
