need help with bike - Kawasaki ZX-10R.net
post #1 of 10 Old 01-11-2009, 03:04 PM Thread Starter
need help with bike
bike was makeing funny sound so i change the cam tension sound stop but came bake and i have a lack in power my friend has a dyno so we put it on there and max hp was 82 any ides of whats wrong
a1cblaine is offline
post #2 of 10 Old 01-11-2009, 03:30 PM
zx10forme's Avatar
Hopefully,something simple,like a loose spark plug.
zx10forme is offline
post #3 of 10 Old 01-11-2009, 03:39 PM Thread Starter
and the bikes goes in every gear
post #4 of 10 Old 01-12-2009, 11:43 AM
SpazOnaZX's Avatar
....check your compression/leakdown on all your cylinders first. If that checks out, start hunting for loose wires. I believe the crank trigger wire and the ECM/engine harness (the one you'd plug the PC3 into) are all in that area.
...this is of course assuming that you're not getting any FI lights? And that you can verify that the bike is getting good fuel pressure and WOT signals? There are far too many things it could be to speculate.... you need to troubleshoot and elimate all the basics first if you want to get anywhere fast.
SpazOnaZX is offline
post #5 of 10 Old 01-12-2009, 11:51 AM
Postwhore with an 04
bcm0018's Avatar
You just have to start a process of elimination to narrow down what the problem is. Good luck!
bcm0018 is offline
post #6 of 10 Old 01-12-2009, 04:47 PM Thread Starter
no the not getting any FI lights
post #7 of 10 Old 01-12-2009, 05:36 PM
edouble's Avatar
I would do a compression test and go from there. If the noise is a loud banging noise as if you where hitting a piece of sheet metal with a hammer it is probably a bearing. But at this point with having a drastic reduction in power something serious is wrong.
It is hard to predict the issue without "hearing" the bike.
edouble is offline
post #8 of 10 Old 01-22-2009, 08:03 PM Thread Starter
how do you check your compression/leakdown
post #9 of 10 Old 01-22-2009, 08:12 PM
luckz88's Avatar
Send a message via AIM to luckz88 Send a message via Yahoo to luckz88
i thought 82 hp was typical for a 10? J.K.
can you do a sound clip of the bike and post it on here?
NESBA #88
Madness Racing wishes he could handle the power of a GSXR
All my homies left this site
luckz88 is offline
post #10 of 10 Old 01-22-2009, 08:23 PM
Speed Freak
garth285's Avatar
sounds like maybe cam timing jumped a tooth when you replaced the tensioner,
garth285 is offline
Looking for an 08 bike to make track bike morefire Bikes 4 Sale 0 09-24-2008 12:19 PM
check out this bike on ebay.....is this steve p's old bike??? garth285 Pictures and Videos 5 06-26-2007 12:44 PM
Z31 vs. Honda Street Bike vs. Freddie Spencer on a 500cc GP Bike circa 1985........ SP8 Pictures and Videos 17 04-01-2006 08:36 AM
Using a 2 bike trailer setup with only one bike - Is it safe? RichTJ99 The ZX-10R 12 08-03-2005 03:35 AM
The Bike of Frankenstien: New Moto GP Bike Vonstallin The ZX-10R 10 11-22-2004 04:42 PM
