NEED HELP ASAP...08 zx10 front wheel bearing - Kawasaki ZX-10R.net
post #1 of 6 Old 08-06-2010, 10:59 AM Thread Starter
KIRK_ADAMS's Avatar
Question NEED HELP ASAP...08 zx10 front wheel bearing
I need the size of the front wheel bearing...I need the I.D., the O.D. and the width....ASAP......thanx for helpin..!!!!!!
Stock motor, Grudge ZX10 (( Walter White ))
https://www.facebook.com/kirk.adams.758
KIRK_ADAMS is offline
post #2 of 6 Old 08-06-2010, 11:29 AM
Supercharged Mod
I don't have it on hand, but the 4-digit numerical code, the first digit of which will always be "6", that is engraved into the bearing you already have in your wheel right now, will tell a bearing shop all they need to know as far as the dimensions are concerned.
GoFaster is offline
post #3 of 6 Old 08-06-2010, 12:43 PM Thread Starter
KIRK_ADAMS's Avatar
dont have the bearing on me right now....kinda looking for id od and width if anyone has them handy?
post #4 of 6 Old 08-06-2010, 01:11 PM
BANNED
This is for the FRONT wheel of 2006-2010
6005 = 25X47X12
25mm ID (axel)
47mm Outside Diameter
12mm wide
The FRONT wheel for 2004-2005 is a 6004 = 20X42X12
I am not going to try and explain the entire coding system, suffice it to say the last number of the bearing size multiplied by 5 = inside diameter or the size of the axel.
In this example the 08 uses a 6005 front wheel bearing. Thus 5 X 5= 25MM inside diamter or axel size.
In the case of the 04-05 (6004) 4 X 5 = 20MM inside diameter or axel size.
MagicMavis is offline
post #5 of 6 Old 08-06-2010, 02:21 PM Thread Starter
KIRK_ADAMS's Avatar
6005 = 25X47X12
25mm ID (axel)
12mm wide
Thank u much...!
post #6 of 6 Old 08-08-2010, 06:28 AM
TENN10's Avatar
Images: 145
Originally Posted by KIRK_ADAMS View Post
Thank u much...!
I've got some spare NSK non contact bearings.
LMK if you need them. I bought extras when I bought mine.
TENN10 is offline
FS: All Balls Racing 2006-2007 ZX-10R Front Wheel Bearing set Vio Parts, Gear and Accessories 1 07-03-2010 12:48 PM
WTB: Front Wheel ASAP Yogurt Wanted: Buy or Trade 0 09-13-2008 05:18 PM
WTB: Front Wheel ASAP Yogurt Wanted: Buy or Trade 1 09-09-2008 10:44 AM
will 04/05 front wheel fit 06/07 zx10? Wahed Performance and Tech 3 09-05-2007 09:30 PM
04 front wheel bearing and seals hesaves0211 Vendors deals 6 06-22-2007 01:15 PM
