need help - Kawasaki ZX-10R.net
post #1 of 6 Old 04-01-2008, 04:40 PM Thread Starter
dabeast664's Avatar
need help
What is up everybody? I did a squid move in remove the plastics off of my 04 without marking the bolts. So the problem is that I need to know where the bolts for the upper fairings and the headlight assembly look like. I did all searching but all I can find was about race bodywork. To make a long thread short hhhhheeeeeeellllppppppppp!!!! P.S. pix will do to
dabeast664 is offline
post #2 of 6 Old 04-01-2008, 07:09 PM
ducatiryder89's Avatar
Images: 21
Post up pics of the bolts lined out and pics of what needs to be put on.
ducatiryder89 is offline
post #3 of 6 Old 04-01-2008, 09:18 PM
Postwhore with an 04
bcm0018's Avatar
You might be able to look at the parts diagram on kawi's website. I'm not sure if they list the bolt sizes with the part numbers or not.
bcm0018 is offline
post #4 of 6 Old 04-02-2008, 03:19 PM
themightymezzo's Avatar
Yeah I'd look at a microfiche or something.
I'll see if I have any pics from previous removals or anything but I don't think so.
For future reference I usually use a plastic baggy and a sharpie and label each bag w/ where the screws/bolts came from, i.e. upper right fairing, gas tank, etc.
themightymezzo is offline
post #5 of 6 Old 04-02-2008, 04:15 PM
2fast10's Avatar
For future reference try always screwing the bolts back into the holes they were removed from after you get the part(s) off... that way it keeps your garrage clean and your bolts organized
2fast10 is offline
post #6 of 6 Old 04-02-2008, 06:56 PM Thread Starter
dabeast664's Avatar
thanks guys I can always count on this forum to get the job done. BTW the job is done
