need help - Kawasaki ZX-10R.net
post #1 of 19 Old 04-13-2013, 08:00 PM Thread Starter
tilts06zx10r's Avatar
need help
ok, so i did the extension and lowered and now i need to know what to do about the sagging on the passenger end. my wife is on the smaller side but im not so when we both are on it and go over a big bump the tail hits the tire. what to do? remember, i have a budget lol
tilts06zx10r is offline
post #2 of 19 Old 04-13-2013, 08:06 PM
BigCat for Prez!
BigCat10R's Avatar
be careful with that man. my wife is 120lbs and used to ride all the time when i had extensions but the first time she rode after id lowered mine i snapped them.
BigCat10R is offline
post #3 of 19 Old 04-13-2013, 08:09 PM Thread Starter
[QUOTE=BigCat10R;2135450]be careful with that man. my wife is 120lbs and used to ride all the time when i had extensions but the first time she rode after
what made the difference? also how do i upload a pic?
post #4 of 19 Old 04-13-2013, 08:16 PM Thread Starter
Name:	zx10r extended.jpg
post #5 of 19 Old 04-13-2013, 08:25 PM
BigCat for Prez!
BigCat10R's Avatar
the swingarm angle becomes inverted once lowered with both of yall on the bike, and the extensions wiill be at an inverted angle to the swingarm itself and with the rotation of the chain putting upward force on the back of the extensions accompanied with road conditions it will put a lot of tension on the end of the swingarm where it meets the extension and will cause a stress fracture.
post #6 of 19 Old 04-13-2013, 08:27 PM
BigCat for Prez!
BigCat10R's Avatar
look at the pic off ur bike, see how shallow of an angle the swingarm is at with nobody on it? put u on it and ur girl and itll be inverted at the pivot and inverted where the extension bolts up and will eventually crack from the bottom up, right in the Z in ZX on the chain side. I had those exact same ones
post #7 of 19 Old 04-13-2013, 08:32 PM
BigCat for Prez!
BigCat10R's Avatar
Theyre fine if u dont lower the bike. i rode for a yr or so with my wife no problems but as soon as i lowered it and she rode, this happened after an hr or so
post #8 of 19 Old 04-13-2013, 08:52 PM Thread Starter
DAMN!!!!! thats scary!!!!
post #9 of 19 Old 04-13-2013, 09:03 PM
BigCat for Prez!
BigCat10R's Avatar
yep...We were lucky it didnt break apart on the interstate or we prolly wouldnt be here
post #10 of 19 Old 04-13-2013, 09:20 PM
Post Whore
-Op-'s Avatar
Unlower the bike a little bit. Itll definently help with that. Is your suspension set up for you? If not, add a turn of preload to the shock and make the compression stiffer, like 1/2 turn out from full hard.
-Op- is offline
