Need to go faster!! - Kawasaki ZX-10R.net
post #1 of 23 Old 02-17-2015, 01:24 AM Thread Starter
Jstamm33's Avatar
Need to go faster!!
So I'm in a bit of a pickle. I have a 1/2 mile roll racing event coming up in April and will be running my 2011 against a '14 s1k with full exhaust and tune. A summary of what's already done to my bike: guhl ecu flash, bmc race filter, Austin racing exhaust (slip on), 1/6 throttle mod, bazzaz qs4 usb, vortex rearsets and clip ons, -1 tooth on the front sprocket, all emissions removed, still have secondary throttle bodies in, GPR steering stabilizer, pcv with custom tune.
So if you had $1500 to put into the bike, what would you do? Head work?
Thinner headgasket? Ceramic wheel bearings? Lighter wheels? Any advice is appreciated :)
Jstamm33 is offline
post #2 of 23 Old 02-17-2015, 01:34 AM
SpazOnaZX's Avatar
Nitrous.
SpazOnaZX is offline
post #3 of 23 Old 02-17-2015, 08:05 AM
gazx10's Avatar
put a multifunction hub on it to switch maps and good mr12 throttle position tune. pick up 10+ hard and $$$ to find hp in midrange and 8-9 up top. used hub about $75, custom tune ,hub, and 5 gal. of fresh mr12 about $500. yeilds good power increase everywhere tuned properly without cracking valve cover. we get these same results everytime. 10's really respond to mr12 done right. just for special ocassions as u mentioned, best for sure power adder option. huge difference riding our bikes on mr12 and pump gas andf were pump gas tuned also.
gazx10 is offline
post #4 of 23 Old 02-17-2015, 09:25 AM
SpazOnaZX's Avatar
Good info, for sure. But goddamn is MR12 expensive.
By contrast you can set up a small, cheap dry shot for less than 500 bucks and make 30-40hp pretty easy. It's a hassle to refill bottles and hide it (if that's your intent), but it can be done. IMO there is no cheaper way to bolt on 30-40hp in a hurry. If he's just going to roll race there's not even really a need for a progressive controller or the other stuff that makes it expensive.... though better clutch springs are always a good idea.
Just out of curiosity, how does MR12 like spray?
post #5 of 23 Old 02-17-2015, 10:17 AM
gazx10's Avatar
dont recommend spray on mr12, lower octane very fast burn fuel to maximize cyl. pressure. spray will work. dont know where u will hide even a 1lb bottle set at effective angle for proper nitrous flow to solenoid on a gen 4. 40 actually pretty big shot on a ten, will lose bottle pressure very quickly in just a few seconds with that size bottle making a/f very rich as nitrous flow decreases. ive run shots as low as 16 hp and picked up 6 mph in the 1/4, recommend maybe 16-20 shot max for that distance for engine safety and correct nitrous a/f fueling thru the run.. both suggested mods require seperate map and tuning. u can spray that shot very safely on pump gas. only gonna get 1 run in on small shot at max power for that distance. mr12 increase will stay consistient for a day or two in the tank, but does require draining the fuel, replacing with pump gas when not being used.
gazx10 is offline
post #6 of 23 Old 02-17-2015, 12:55 PM
slothman's Avatar
spray the bitch. 20-30 shot will do nicely. change the plugs for 2 steps colder. No need for race fuel, just run a little bit of torco. Nitrous can be used safely, just don't be stupid with it.
slothman is offline
post #7 of 23 Old 02-17-2015, 01:04 PM
Teeks's Avatar
how much $ is at stake in this race? I assume its a lot of your willing to drop $1500 to win. I will also assume that if you are willing to drop that kind of $$ so is he. That said I would spray it and hire a jockey
Teeks is offline
post #8 of 23 Old 02-17-2015, 01:17 PM
SpazOnaZX's Avatar
Rep, fo sho. :)
post #9 of 23 Old 02-17-2015, 01:24 PM
slothman's Avatar
slothman is offline
post #10 of 23 Old 02-17-2015, 04:20 PM
gazx10's Avatar
no need to change plug heat range on 20-30 shot.
gazx10 is offline
Need to be faster customoverload The ZX-10R 27 03-12-2012 09:13 PM
Gen 1: must go faster!!! skatermckimm Performance and Tech 31 03-28-2011 01:07 PM
Went a little faster. GARSZX10R Strip 13 11-15-2006 02:23 PM
Faster!!!! greenmonster The ZX-10R 23 09-10-2004 07:00 PM
