Need clutch help - Kawasaki ZX-10R.net
post #1 of 3 Old 05-21-2007, 08:22 AM Thread Starter
fpzx10's Avatar
Need clutch help
The other day I noticed that when the bike is off and I pulled in the clutch to roll it that it was hard to roll. So I knew something was wrong. I put it on the rearstand and, sure enough, the wheel spins freely when the clutch is pulled in. Can this be fixed with a clutch cable adjustment or is there something else I need to look at and/or fix.
Thanks in advance for the help
fpzx10 is offline
post #2 of 3 Old 05-21-2007, 11:02 AM
Just put in neutral before you roll it... problem solved.
I suggest no less than 3 mm of free-play on the clutch cable.
fordfasterr is offline
post #3 of 3 Old 05-21-2007, 08:58 PM
Vince10R's Avatar
put it in neutral or the clutch will drag with the engine off
Vince10R is offline
Need clutch help fatcalvin Performance and Tech 9 02-22-2007 03:07 PM
CRG Clutch Blk Clutch Lever & Lightech Gas Cap yehzx10r Vendors deals 2 09-25-2006 05:25 PM
clutch tank zx10r Vendors deals 1 08-22-2006 07:07 PM
on my 3rd clutch now DethsZX10 The ZX-10R 17 08-30-2005 04:18 PM
slipper clutch & clutch plates... jarhead05 Performance and Tech 14 07-07-2005 03:13 AM
