Need brake failure help!! - Kawasaki ZX-10R.net
post #1 of 13 Old 11-30-2009, 02:15 PM Thread Starter
formerly GHOST RIDER
SOUN1's Avatar
The front brake on my 05 ZX6R is locking up on me..Seems like it get hot and pressure builds and locked up..It happen to me once on the track (over the bars I go)..and this weekend, not even a lap (waiting at the pit) and pressure builds up.!! I'd changed the whole front brake system (stock) and it still happen again..I don't think it's the brake system now, what's the chances of 2 brake system fail the same way..My rotors and wheel looks straight, I spined it off the pavement and it looks okay. The fork shows no sign of damage..How do I check if my forks are slightly bent or off..Any tip(suggestion) is very helpfull at this moment.
SOUN1 is offline
post #2 of 13 Old 11-30-2009, 02:18 PM
zx10Duran's Avatar
wonder if your rotors are warped? or your calipers have dirt in the piston and not letting them retract
lotta newbies, where did all the regulars go?
zx10Duran is offline
post #3 of 13 Old 11-30-2009, 02:20 PM
zx10Duran's Avatar
either way I have a M/C for the 05 zx6 if you decide to replace parts
post #4 of 13 Old 11-30-2009, 02:33 PM Thread Starter
SOUN1's Avatar
I'll keep that in mind but 2 sets of brake system doing the same thing?..I must be something eles..How much are you looking to get for it?
Next? Will my 05 ZX10R system fit my 05?
SOUN1 is offline
post #5 of 13 Old 11-30-2009, 03:07 PM
everything clean?
I had a bike do the same thing. there's a tiny hole in the master cylinder that allows pressure to release once you let go of the brake lever. mine had plugged up with gunk, and wasn't allowing pressure to release.
That was on an old bike though that had been sitting for years. Not sure how it could happen on a new(ish) bike.
If it aint broken, it doesn't have enough features yet
There are 'glass half empty' people, and 'glass half full' people. Then there are engineers who see that the glass is twice as big as it needs to be.
Chubbs is offline
post #6 of 13 Old 11-30-2009, 03:14 PM
Supercharged Mod
Is your master cylinder vented to the reservoir when the lever is released?
The tiny vent hole inside the master cylinder must be uncovered by the front of the piston to vent it to the reservoir when the lever is released, otherwise the symptoms will be exactly as you describe. The fluid as it warms up won't have anywhere to go as it expands, this causes the brakes to apply harder.
The other symptom of this will be that the brake lever gets really firm with little or no lever motion before the brakes are applied.
Usual causes of this stuff are improper adjustment of the lever, wrong lever for the master cylinder, bent brake lever so that it won't let the piston go all the way back, etc.
GoFaster is offline
post #7 of 13 Old 11-30-2009, 04:25 PM Thread Starter
SOUN1's Avatar
Thanks guys..I'll check and do as advise here and see how it goes. I'll come back and pick you guys brain again later..I got 4 months before another track day.
SOUN1 is offline
post #8 of 13 Old 11-30-2009, 05:21 PM
bugman53's Avatar
bingo......if you have aftermarket levers and the lver is not fully released then it will do just like you decribed. make sure the lever is not binding up. A metal file to clean up the lever and your set. Could also be the vent clogged. but i have seen the levers cause this problem more then once
High Velocity Cycles 2005 Ti ZX10R
Greeensboro NC
bugman53 is offline
post #9 of 13 Old 12-03-2009, 04:05 AM
it's definitely a lever, master cylinder pblm. i f you got aftermarket levers make sure you adjust them to pos 6 (biggest distance handle to lever) and try again, specially on track use oil heats up and if lever is on pos 1, it can cause binding . further you might want try to put stock levers back on and check whether it still happens if AFM levers are not correctly fit, manufactured they might cause that effect as well as master cylinder never releases, i.e. expansion reservoir of brake fluid will be disconnected and causes seizing of brakes.
MarcelZX10R is offline
post #10 of 13 Old 12-03-2009, 04:09 AM
greenman43's Avatar
Images: 33
I had exactly the same happen when fiddling with another bike, and it turned out to be just this.
Cheers,
Brian
Do not walk behind me, for I may not be leading.
Do not walk in front of me, for I may not follow.
Do not walk alongside me, for the path may be narrow.
Just piss off and leave me alone.
greenman43 is offline
Not a how to but generater failure. pics. 10 speed Performance and Tech 87 04-11-2012 08:58 PM
intermittent headlamp failure??? danno46 The ZX-10R 16 05-15-2011 05:37 PM
07 ZX-10 Power failure onewu10 Performance and Tech 14 03-09-2010 07:30 AM
Thief failure GoFaster The Out House 9 05-26-2009 08:36 PM
Clutch cable failure @ 5k mi??!!?? gladding24 Performance and Tech 4 09-18-2004 06:59 AM
